Question about Invicta Watches
Model no 6189 the pin that locks the watch to the metal braclet is missing the nut how can i get a new nut?
  • 831 Answers
Movado 0605781
Based on the picture my guess would be size 3. If I were you I would take that to a local shop. I charge $5 to provide and install spring bars I can't see you getting them for any less than that anyway. Might as well have someone else do it for you.
Nov 28, 2013 | Movado 605638 Watch
Remove links from braclet
does this expand? or links.if its pins they need to be punched out, look inside there should be arrow.
Mar 23, 2012 | Dunhill Millenium DC2601M Wrist Watch
Altering the ******** a watch braclet 6,418,706 B1
use a fine pointed tip tool such as the prong of a fork and between links on bracelet there is a pin between each.. use prong to press out the pin
Feb 22, 2012 | Fossil Blue watch #AM3574 Watch for Men
How can I remove link pins to adjust metal band from Raymond Weil ladies Tango 527462? One side of the pin has a slot head but a very small screw driver fails to turn the head. The other side has a flat...
Raymond Weil watch braclet has a screw. Twist it, and then push from the other side. You may need to buy a set of basic tool for about 10 dollars from Amazon. Good luck and enjoy your watch. Alan Anderson
Nov 09, 2010 | Raymond Weil 5360-STP-00328 Wrist Watch
Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
Braclet has come off watch.
It is difficult to be sure what the problem is without examining the watch but it sound as if the pin spring (which which makes it telescopic) has broken.
It should be possible to get arepalcement from you local watch shop, they usually have a range standard items to fit most watches.
Jun 30, 2010 | Rolex Submariner 16618 Wristwatch
I need replacement screws for my band lds philip stein teslar
mcdevito75 here, Best Bet, visit a small watch repair shop in your area for these screws.
Jun 28, 2010 | Philip Stein Teslar Diamond White...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
May 24, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
54 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
