Question about Car Audio & Video
Trying to install after market cd player in freightliner. need wiring diagram or wiring harness adapter. model # 12244075
I have got the same problem. took out factory stereo out of my 2005 m2 106. only to find all wires to be gray with no markings. it has a 12 pin connector. can anyone tell me the how to hook-up new regular 10 wire cd player
Posted on Nov 07, 2010
Trying to install an after market stereo into my 1999 Hrand am. The wiring harness was cut from the wires, so question is what wires from the car connect to which wires from the cd player(which colors go...
You'll need to go to support site for manufacturer of stereo and check for a download for owners manual which will give wiring diagram for stereo. Have your model number ready. Then go to (http://www.the12volt.com/) and they have wiring info for your vehicle.
Jun 29, 2011 | 1999 Pontiac Grand Am GT
Installing after market radio need factory wiring diagram for 1996 ford f150
Try chrutchfield.It is easy to spend a couple of bucks for a adapter.Then you just wire the radio an plug it in to the factory harness.You can also try any local box store that installs radios,they will have the adapter harness.Well hope this helps.
May 16, 2010 | 1996 Ford F150 Regular Cab
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
1991 Ford Tempo Stereo Wiring
you need a wire harness for your car you can buy them at most auto parts stores make sure and buy the one for your make and model they should have instructions and the wiring diagram most harnesses are color coded and pretty simple to install
May 15, 2009 | 1991 Ford Tempo 4 Door
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Can not find wiring harness for '95 lincoln towncar
If you cant find the wiring harness i'd suggest you snip the adapter of and join the wires up *Correctly of course*
Modern CD players normally have a sticker or information on which wire does what on the CD player.
You just have to work out the ones on the Lincoln then.
Jan 19, 2009 | 1995 Lincoln Town Car
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Car Audio & Video Logo
660 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
