Question about Kenmore 44102 Front Load Washer
Water does not go into the washer, you can here the motor working but no water
  • Kenmore Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on Aug 24, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Washer fluid does not dispense on rear window of 2003 c240 mercedes
check the small housing that comes from washer bottle make sure that thats all attached if thats ok stick a pin in the jet as a build up of muck can get stuck in it blocking the jet up
Jan 25, 2014 | Mercedes C-Class Exterior Pillar Posts...
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
I have lost the pressure of water but the motor is still working.
If the motor was ran without the water being attached to the washer it would crack the pistons which is what creates the water pressure for you.
Aug 18, 2012 | Karcher K 391m Pressure Washer
My front windshield wiper pump does not pump washer fluid but the wipers work fine , the back wiper and pump works
First make sure you have water in washer reservoir, with ignition on reds (not started) then get someone to operate washer while bonnet is closed otherwise the wipers (may come on) may damage your bonnet (would also be a good idea to throw some water on your screen before commencing), listen for a buzzing noise, if you can hear that noise than your washer motor is ok, if not - if fitted with fuse check it and if fuse is ok than your motor needs attention. If motor is ok than while someone is operating the washer motor look under the car to see if there is any water leaking, if there is water leaking than the hose going from your washer bottle to your washer nozzles has come off somewhere, visually check this hose, usually small diameter and clear in colour, reconnect or replace it. If there is no water leak and you have full water and motor is working, than your nozzle, usually located on the bonnet or wiper arms are blocked, this mainly happens after polishing the vehicle. There are 2 main ways of cleaning these nozzles, easiest way is to get a fine pin and poke it several times, this will clean it 85% of the time, if it does not work than you need to find the hose that connects to it and pull apart at a join, closer to the nozzle the better, and give it short burst of compressed air, have to be careful not to pop the hose out at the nozzle as some of them are located in really awkard points, hope this helps.
Apr 12, 2011 | 2004 Toyota Matrix
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
1999 renault megane sport coupe
disconnect the washer bottle plug connector. then run alive and earth wire direct from battery to washer motor to see if motor works that way, if does then new need a new washer switch on the steering column. if not then replace washer motor. should work after that unless pipes blocked.
Jan 18, 2009 | 1986 Renault Sport
Washers not working on ford focus
check the motor or hose probable clog. hope this help
Dec 17, 2008 | 2001 Ford Focus
Kenmore 44102 Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
