Question about Sport & Outdoor - Others
Repair manual for True 825 S.O.F.T. System ZTX 825HRC Treadmill
4 Suggested Answers
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
maxtreadmill
  • 832 Answers
SOURCE: My True 825 treadmill will
I'm sorry to say that the upper electronics is shot, the eprom is where the program software is located. In matter of speaking - it for the most parts lost its mind !! Call True Tech Support @ 1-800-883-8783 and see what it will cost to replace the upper electronics.
Good Luck!!
MAX
Posted on Sep 25, 2010
  • 95 Answers
SOURCE: where can I download a
FitnessRepairParts may be able to sell you a manual if you can't find it anywhere, depending on which version of the 825 you have (there are quite a few.. check for other model numbers on your machine
http://www.fitnessrepairparts.com/part_search/EquipmentSearch/weslo%20cadence%20825
You can also try IconService.com and click on "Manuals" - sometimes they have manuals you can download or purchase.
Posted on Oct 05, 2010
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
My cadence 825 had been unused for a while but now when I insert the plastic key the treadmill starts immediatly without my having control over it. where can I get some maintenance for this machine. Kevin...
RUN the software calibration for diagnose, troubleshooting , fix it.
adjust the speed sensor, clean it and tight the wires connector
LUBE the deck belt+rollers bearing too
SEE THE diagram.
God bless you
Jul 19, 2012 | Cadence Weslo 825 Treadmill Walking Belt
Where can I download a manual for a Weslo Cadence 825 treadmill
Oct 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
My True 825 treadmill will not run and the display shows E3 EEEPROM. What do I do?
Good Luck!!
MAX
Sep 24, 2010 | Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Good luck, Tim
Nov 24, 2009 | Cadence Exercise & Fitness
We have a Cadence 825 treadmill and the display has quit working. How do we fix it?
either the console is bad (which is no longer available) or the control pwb is bad (available for $114 on iconservice.com) Check for power to the controller. Red light should be on. (you must remove the hood cover 4 screws 2 on the sides and 2 in the rear) If light is on the controller then more than likely you have a bad cosole as I said it is apparently no longer available.
Nov 09, 2009 | Cadence Weslo 825 Treadmill Walking Belt
My Cadence 825 is running on walking speed only when I'm on it but speed up when I'm not stepping the belt. It also makes burring sound when switched on and I can smell burning too.This is a 13 year old...
You actually used the opposite treatment that was needed when you used the lubricant spray. You want the belt to not slip but instead grab to the belt driver. Now, the lube should be removed and instead the powder that causes the belt to grab hold should be applied. You may want to call any treadmill store and ask them what they charge to do a maintenance on a treadmill like yours.
Oct 01, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Sport & Outdoor - Others Logo
645 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
