Question about Whirlpool Dryers
Dryer tumbles but dont heat - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor with an ohm meter or by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Aug 24, 2010
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
? 2:33
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Nov 28, 2015 | Candy Dryers
Tumbles but dont dry
74632 is not a model number. But what you have stated the dryer probably has a bad thermal switch. Cost around $6-8. Unplug dryer, remove back, with a tester test everything that has wires hooked to it. Test from one side to the other to see if power goes through, if not replace that part. They are small round or small rectangle with two wires connected to them. Check the one one the duct first, this one usually goes bad. Vacuum out all lint out of dryer and hose to exterior, excess lint will cause dryer to heat up and blow this part.
May 08, 2010 | Kenmore 74632 Gas Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
Open Questions:
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
