Question about Dell Optiplex 755 Desktop Desktop Computer
I have a dell optiplex 755 there is a blinking orange or amber light when i press the power button can you help me please...
  • 1,472 Answers
Kcvictory
If you are getting a blinking amber light this is normally related to a power problem. So the first thing I would try resetting the flee power. You do this by unplugging the AC power and holding the power button in for 30 to 45 seconds. After you do this plug back in the AC power to see if the system will boot. If it will not the next thing I would look for is the diag lights to see if any are lite up. They are normally near the front USB unless you have a small form factor case then they are on the back. Then will point to a hard ware problem if any. If they are not lite up then most likely the problem is with the powersupply.
Note if you are still in warranty I would pass this info over to Dell and they should be able to get your system fixed.
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Posted on Aug 24, 2010
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
OptiPlex 755 flashing orange light only
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Aug 27, 2012 | Dell Computers & Internet
Optiplex 755 showing orange colour light on power button.. how can i fix this problem
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 24, 2012 | Dell Optiplex 755 Minitower Desktop...
IN dell optiplex sx280 model system we are using in this amber power led blinking continuly yellow color because of this not able to boot the system. kindly give the solution for the same
Hi there!
A blinking amber/orange light on the power button of your Dell Optiplex means a hardware failure. If you know how to strip down your computer to basic component, then I suggest you turn on with only the motherboard, processor, memory and PSU. If you are not familiar with this, I suggest you bring the computer to a qualified technician.
Hope this helps
May 09, 2011 | Dell OptiPlex SX280 PC Desktop
Please my dell optiplex 755 does not power but the on-board light is on. it only has a yellow light always blinking on the power button. how do i solve this problem?
Replace the power supply.
Generally this is a dell diagnostic light feature tellign you the power supply is failing. Have the unit tested and get a replacement.
Jan 24, 2011 | Dell Optiplex 755 Minitower Desktop...
I have Dell Optiplex 755 dekstop i have power on problem. Orange colour light is blinking
The problem of blinking amaber light is usually caused due to a bad power supply on the computer. Open the system tower and reseat the biggest bunch pf cable connected to the motherboard. its titled P1 and it the biggest white connector. If the same doesnot resolve the problem you would have to replace the power supply on the motherboard.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell Optiplex 755 Minitower Desktop...
Optiplex 755 flashing orange power button light only
Sounds like you only have power going to your motherboard.
The power supply might be bad on it, that or maybe the power cord is going bad and is only letting a small amount go through. I don't see why there should be a problem if you have even a little bit of power going though.
Jul 11, 2009 | Dell Optiplex 755 Minitower Desktop...
My dell pc still not working
An orange/amber light is almost always a power problem. Is the amber light on the monitor or the PC itself? I'm assuming the PC since you have the ability to read the screen. Your best bet is to check your power supply in the PC. Do you have a power supply tester (about $20) or another PC? You can switch them out and see if the orange light follows the power supply. Let me know what you find out.
Feb 11, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex 755 Desktop Desktop Computer  Logo
428 people viewed this question
Alun Cox
