Question about Ovens
It will run but food will not get hot. - Ovens
  • Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 24, 2010
Whirlpool oven will only get to 250 degrees, help
250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
Sep 24, 2015 | Whirlpool Ovens
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Microwave is not make food hot
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 05, 2011 | Whirlpool Ovens
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
I can't open the oven door all way so I have to reach over it to place food in or take food out of the hot oven.
Sorry to read about your problem, I hope this helps you out.
a little spring has sprung on your door
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven is burning food and seems too hot
HI. the oven temp sensor is malfunctioning. have it inspected for damage. check the wires leading from the control to the sensor for cuts and damage as well. replace the sensor if these issues with heating persist.
Sep 20, 2009 | Ovens
How does self cleaning work on my frigidaire gas burner stove?
Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
Nov 28, 2008 | Ovens
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
