Question about Euro-Pro Shark GI490 Iron
How do i clean the iron? - Euro-Pro Shark GI490 Iron
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Aug 24, 2010
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Tefal Gv8110 Steam Generator Iron no Steam
follow this steps. God bless you
Nov 10, 2012 | Irons
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    How to repair aan electrical iron
    If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
    If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
    If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
    If the iron does not spray properly, inspect and clean the nozzle.
    If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
    The tools you will need are
    • Screwdrivers
    • Toothpicks or pipe cleaners
    • Sewing needle
    • Commercial electric iron cleaning solution or vinegar and water
    • Commercial sole plate cleaner or baking soda and water
    • Steel wool
    • Emery cloth
    Please rate my solution.
    Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
    It is sticky and looks like glue.It looks gooey
    Hello :
    Here I'm going to tell you the basics of cleaning your Rowenta iron :
    Things You'll Need:1:Rowenta Soleplate Cleaning Kit
    2: Ironing board
    3:Clean, dry cloth
    4:Two cotton terry cloths, such as washcloths
    Now to the cleaning :
    1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
    2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
    3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
    4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
    5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
    PLEASE RATE !
    Apr 20, 2010 | Rowenta DX6700 Iron
    How do I clean my iron? The iron part on outside
    Here is a tip that will help you with cleaning the bottom of your iron...
    heatman101
    Apr 05, 2010 | Black & Decker Steam Xpress AS250 Iron...
    Re: cleaning the iron
    heatman101
    Mar 07, 2010 | Tefal UltraGlide Easycord FV4256 Iron
    Trouble cleaning Sunbeam iron 3983
    you can buy an iron cleaner from your hardware store, wallmart sell it.
    Jun 09, 2009 | Sunbeam Best Value 3983 Iron
    Euro-Pro Shark GI490 Iron Logo
    59 people viewed this question
    Top Euro-Pro Irons Experts
    Henry  Thomas
    Henry Thomas
    Gil Shultz
    Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
