Question about Polaroid Cameras
I have a one year old Polaroid a930, hardly used, that I'm having problems with. When I turn it on it shuts itself off again immediatly. I have tried with a memory card and without, I have changed the batteries repeatedly without succes. What is the problem.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 24, 2010
My polaroid a930 digital camera won't download pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 20, 2013 | Polaroid a930 Digital Camera
My a930 polaroid does not focus well at all what can I do??
This could very well just be the nature of the camera-- are you attempting to take pictures in low light? This can cause difficulty for the camera to focus. If the camera is having trouble focusing in broad daylight, then there is likely some problem with the autofocus system that would need to be examined by a camera repair shop. The repair on a point and shoot camera like this one would likely exceed the value of the camera.
Mar 10, 2011 | Polaroid a930 Digital Camera
Why does my Polaroid camera a930 take blurry pictures?
The lens is probably out of focus. Try fixing it or just getting a new camera.
Jan 12, 2011 | Polaroid a930 Digital Camera
I have a Polaroid a930. It doesn't want to take picture when the memory card is in. It says 'card protected' all the time!!! Please help!
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 10, 2010 | Polaroid Cameras
Polaroid FLM-3732 Television turns on then off
A common problem with this television is the power unit. Some of the capacitors go out on them within 2 years. You can buy a replacement power unit for about $150 or if you know how to use a soldering gun you can purchase the capacitors for about $5 and fix the unit yourself.
I just fixed my Polaroid 3732 and it cost me $3.49. I would push the power button and the standby light would come on but the picture would not appear. After I changed the capacitors it starts right up.
May 02, 2010 | Polaroid FLM-3732 Television
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Memory card problem !
if you could be aable to copy the files in your computer,do so and try formatting the memory card from the camera itself, memory card might be using a different file format
Jul 25, 2009 | Polaroid i737 Digital Camera
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 06, 2008 | Digimate DGL26 Television
Polaroid hdtv
If your LCD is less then a year old, still under manufacturers warranty.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured or hard to find. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Nov 27, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Cameras Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
