Question about Garmin GPS
I have a Garmin 2006/2010 GPS 17N installed on my boat. During a trip this week I lost antenna/gps reception and it never came back. Tried unplugging turning off and on, nothing worked. Everything appears to be plugged in correctly. Any suggestions?
mattozan
  • 555 Answers
SOURCE: GARMIN GPS
Trip & Waypoint Manager should be all you need.
The USB drivers should have been automatically installed when you installed the program. If your computer prompts you for the driver location when you connect your GPS via USB, then you'll just need to reinstall the latest drivers (one time only--after that the computer should automatically detect and use the GPS whenever it is plugged in)
The latest drivers for your unit can be downloaded here. There is a new version (v.2.2.1) as of about one year ago.
Posted on Apr 04, 2008
SOURCE: satellite reception
I have being having similar problem as every one else. There is nothing wrong with your Nuvi. Garmin (the company is the problem) they are trying to make you buy a new map--Not Exactly Cheap--Do Hard Reset and solve all the problems.
1) Place a finger (Any finger, middle finger worked for me!) at the left lower corner and turn on the Nuvi unit a message appear saying "Do you really want to start up in maintenance mode?" tap Yes
2) At the Maintenace screen tap clear user data (this will restore to factory condition) and follow the instruction on adjusting your prefered setings.
3) turn it off and Repeat step 1, this time when you get to maintance screen tap on "Clear waypoints" and follow the instruction. Let it sit for about an hour then voila.
Posted on Jun 18, 2008
sharcnet
  • 2130 Answers
SOURCE: my Garmin Nuvi was working
Here is an email received directly from Garmin: I have tried this myself on several units and it worked. I can't gurantee it will work for all cases. In some cases the antenna may be defective. Also, click on the "wrench" symbol, then the "gear" symbol and then "about". Look at the number after the text "GPS S/W:" It should be a number like 2.9 or 3. If its 0.0, then the antenna is not communicating with the main board.
"Thank you for contacting Garmin International, I am happy
to help you with this.
Sometimes the almanac data that your nüvi stores for satellite acquisition becomes corrupted. This causes acquisition to become slow. To correct this we need to perform a master reset. This procedure will erase all user data.
With your nüvi powered off, press and hold the lower left corner of the screen. Next, turn the power on. Continue to hold the screen until it asks if you really want to enter maintenance mode. Next, choose clear user data. The screen will flicker a bit and then start up like it did when it was first turned on. Follow the directions to set time and location. You will have to reacquire satellites by turning on your nüvi with the antenna up outside in full view of the sky. This one time
acquisition may take up to 30 minutes. "
- Jim
Posted on Sep 24, 2008
  • 4090 Answers
SOURCE: the new GARMIN 255W can not be detected by computer
take it back to seller for replacement or repair
Posted on Jul 06, 2009
  • 4090 Answers
SOURCE: The gps looses satellite reception. Repositioning
DIY is risky in this situation, besides there is 3 months warranty by Garmin on their interventions I would suggest you get it done by the professionals
Posted on Jul 22, 2009
Garmin 545s lost gps signal/reads gps error on satilitte page
Lost Satellite Reception - the unit has lost satellite signals. Check
antenna connections or try moving to a location with a clear view of
the sky.
Jan 11, 2012 | Garmin GPSMAP 545s GPS Receiver
My Raymarine C 120 GPS intermittently stops working.
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Jul 28, 2010 | Raymarine C120 GPS Receiver
Jul 18, 2009 | Garmin Quest GPS Receiver
Does not work in foilege
Not a lot you can do about this afraid.
Some devices specify a optimum handling angle for best satellite reception. For example, my old Nokia N82 phone used to work best on a 45 degree angle!
Jul 02, 2009 | Garmin GPS 12XL GPS Receiver
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 760 loses satelite reception. Tried to reset to factory settings and still having problem.
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
http://cgi.ebay.com/AMPLIFIED-GPS-ANTENNA-FOR-GARMIN-NUVI-760-750-770-780_W0QQitemZ220265873242QQihZ012QQcategoryZ73348QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Enjoy, NGK
Sep 03, 2008 | Garmin GPS
Unable to acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
May 04, 2008 | GPS
GPS
http://www.fixya.com/support/t3119011-quest_2_antenna_contacts_cleaning
The antenna is on a spring loaded hinge and over time can get dirty where it connects to the gps. I have seen instances where cleaning the contacts helped the performance. Just be careful when removing the plastic endcap on the back of the GPS. There is a small spring that can fly out of there and is lost easily.
Feb 21, 2007 | Garmin Quest GPS Receiver
GPS Logo
83 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
