Question about Homelite Garden
Hello. The chain on my chainsaw got tied up while I was cleaning it. Is there anyway to untie it?
  • 10,865 Answers
Yes. just keep working the kinks out and it will come unties, or drill out one of the rivets. J.
Posted on Aug 24, 2010
Chain will spin when I put clutch and bar back together start it up chain spins then stops and clutch gets red hot?
or a to thick chain or the chain was not cleaned after use before a long time The chain may be stiff with tree resin, you have the chain anyway can rotate by hand when the machine is not on the safety brake
Jan 30, 2016 | Garden
Repairing chain
You can repair/rejoin chain, before doing this you need to check the condition of the rest of the chain, if it is badly worn it is not worth repairing, to repair it you need pre set and plain tie straps suitable for the pitch and gauge of the chain being repaired
Mar 01, 2012 | Garden
Can you make a 14" chain from a 16" one?? I have
You can if you have a breaker, some new pre set tie straps , and a spinner, this as you can see is not something you can do at home easily, the local chainsaw shop should be able to help you with this, however will make a charge which may be as much as a new chain.
Oct 08, 2011 | Oregon Scientific Oregon 16Inch Semi...
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
My chainsaw leaks oil out of a small hole or drain just below the base of the bar. is there anyway to way to stop this
are you sure you aren't talking about the chain oiler system? There is to be a small amount of oil to lubricate the bar and chain.
Jun 01, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Husky 345 not oiling chain
Remove the chain plate, Clean it , check oil drain and check oil tank cap is air inlket free.
Mar 20, 2011 | Husqvarna Chain Saw 20" Bar
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain oil is pumping into area where pipe goes under square rubber bush, but not onto the top reservior so the chain can pick it up. Behind the aluminium plate.
Hello. If you haven't done so already ,remove the bar and chain and make sure the slot in the back aluminum plate lines up with the oil outlet hole if so ok. Use a thin tool (utility knife works) and scrape inside the chain groove of the bar to clean it out.Make sure the oil inlet hole in the bar is clean. If it doesn't work after doing this you may have a cracked oil tank,disconected oil line,or worn out oil pump.
builderdale
Jan 11, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chain brake will not reset
Hello. If you haven't done so already remove the bar and chain. The chain brake mechanism is behind the clutch.Clean the whole area with compressed air or a scraper and a shot of engine cleaner if you have some. Look for broken, bent ,stuck or missing parts.
builderdale
Jan 07, 2010 | Husqvarna Forest & Garden #952802239 235E...
Oil has stopped flowing from the tank to the chain.
Hello, Try cleaning the area near the chain where the oil is delivered. Scrape it out well, and then clean the area with a spray of WD-40
Best regards, W/D
Aug 24, 2009 | Poulan Garden
Garden Logo
47 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
