Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Recognize but cannot open
When i inserted my 1gb flashdrive in a computer it recognize it but when the time i open it the message are this "please insert disk"...how can i solve it?tnx....
  • June Salaysy May 12, 2008
    When i inserted my Kingston 1gb flashdrive (DTI/1GBFE) to my computer it recognize it but
    when i go to "My Computer" & open the device, the message are this "please insert disk on drive E". I tried it to other computer but the same thing is happen. Will my Flashdrive can be software repaired?
  • Anonymous May 26, 2008
    I m trying to use a 8GB flash disk. in is recognized by the Windows XP and Linux Ubuntu but when i try to open it i get the following message "Please insert a disk into drive E". Can any one help?
    Scholar:
  • 125 Answers
Are you selecting the correct drive? Usually the message comes from a multi memory card reader with no memory card inserted. Do you have one of those? This drive should say "removable disk". You may need to force a new drive letter for the memory stick.
Go the disk management program in windows. It will tell you moreabout the status of the drive What windows are you running -XP? Then, with the stick inserted, right Click "My Computer" and choose manage. Then disk management and find the USB drive and see what is says. You can force a new drive letter here as well.
Posted on May 05, 2008
  • Kingston Master
  • 27,725 Answers
The driver might need to be updated
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Feb 05, 2012
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
My computer will not recognize my Sansa sandisk MP3 player. I tried to reset it, and when I get the "Please connect USB" message, it still won't recognize it.
Aug 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
Problem
Hello!
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Ken
Jan 06, 2009 | Computers & Internet
SanDisk 1GB microSD Memory Card, computer not recognize card
check it on some different system if the problem persists there is a fault in the card
Nov 14, 2008 | Acer TravelMate 2413LCi Notebook
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
How to install Memorex USB 2.0 1GB flash drive on computer with microsoft 2000 OS
windows 2000 should recognize the flash drive immediately after it is inserted. The flash drive should install itself. Besides, there are only drivers available on the Memorex website for Windows 98se.
Jul 26, 2008 | Computers & Internet
USB plug in recognition
Hello Silvertop01,
This is Romeet, id like to help you with the problem. Unfortunately it seems a lot of things that you love :) wont work right? well, Let me know if you are running windows xp with what service pack? service pack 1 or service pack 2? to do this, right click the icon " My Computer " and select properties,a system properties dialog will open, on the top right you should be able to see:
System:
Microsoft Windows XP
Professional / Home ( Depends what you have )
Version ( 2002 )
Service Pack X ( X could be 1 or 2 )check this and let me know
B.Regds
Romeet
Nov 30, 2007 | Dell Inspiron B130 Notebook
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
461 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
