Question about RCA HD52W59 HDTV Projection Television
Tv turned off by itself now TV button goes on but immediately turns off
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
The flyback transformer are damaged.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Codes for Big Button Remote
If it's an Innovage brand Jumbo remote, try this...
There are 2 different versions of the Innovage Jumbo remote, an old and a new.
For the old version:
1. You have to have the TV or DVD turned OFF.
2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid
3. Then press TV (or DVD) button once till it lights once and turns solid and press the ON/OFF button very slowly and repeatedly as many as 300+ times to wait for the TV (or DVD) to go on.
4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This is very frustrating but my advice is to take it slow and methodical. Think the tortoise and the hare...if you go too fast, you'll redo it several times because you'll keep passing it up and accidentally turn the TV on and off suddenly and miss the code.
For the newer version:
1. Turn the TV (or DVD) ON.
2. Press CODE SEARCH once and it blinks.
3. Press TV (or DVD) once and it blinks.
4. Press ON/OFF button only ONCE.
5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches.
6. Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have to push ENTER to lock in that code before it goes onto the next one. (which it will even if the TV is off)
Apr 16, 2008 | Big Button TV Universal Remote
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Innovage Jumbo Universal Remote
Dec 30, 2007 | Televison & Video
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
RCA HD52W59 HDTV Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
