Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is showing a SP, and will not continue washing. how do I fix this?
  • 5,911 Answers
If this is a Whirlpool Duet series washer, there is no "SP" error code. You are probably getting an "SD" error, which is a Suds lock error code. The washer will not complete any cycle as long as the error code is present. The following link explains the error and some potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error comes from using too much, or the wrong type, of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any manufacturer warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds is NORMAL and preferred.
If you use too much detergent, using the RINSE/SPIN option is recommended to flush the tub, drain pump and lines. IMPORTANT: It can sometimes take SEVERAL cycles to clear. Also, leaving the door open for a while can allow air into a suds filled drum to get rid of some of the bubbles.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Posted on Aug 24, 2010
The queen speed industrial washer machine displays E SP, what must i do?
I suggest obtain the owners manual and follow the troubleshooting tips.
These manuals are usually available for free online as a PDF file.
Dec 15, 2017 | Speed Washing Machines
W10158202A Washer shows F29 Error code.What is this and how it can fix?
Could be the machine is not level.
Unplug the machine
Remove the lower panel on the bottom front of the machine (3 number torx screws). There should be a technical information panel giving error codes etc.
You can manually open the door by reaching up and pulling on the door release tab located below the door switch
May 02, 2016 | Washing Machines
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
How to fix kenmore elite washer 110.270.32603 that continuously shows F1 error code?
I had to call Sears and they sent a technician out. He ordered a new part and it fixed it. Haven't had issues in over a year now.
Jun 12, 2014 | Kenmore Elite 45986 Front Load Washer
Simpson swt802sa
he most common parts or causes, ordered by the likelihood of fixing the symptom.
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
God bless you11c63312-8cb1-4484-928d-4b5c239b0f35.gif243403b0-440d-4f8b-b217-fdfd20c409ef.jpegc0210118-4dbd-4ea4-980b-16577c9769fb.gif
May 23, 2013 | Washing Machines
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
196 people viewed this question
Dan Webster
Dan Webster
Sal De
