Question about Microwave Ovens
Model jes1290sk 02 can it be built into a cabinet? does it require special venting?
    Genius:
  • 1,226 Answers
There should be input airways so that fan won't create vibration in the unit, ventiallation should be observed.
melnavz
Posted on May 05, 2008
    Genius:
  • 3,587 Answers
Yes.on both counts..what can you report about the intended installation area..the key is the rear of the unit, where the fan operates..needs a good 6 to 8 inches of free air space, so that the back pressure doesn't build up and imbalance the flow inside the cabinet of the unit
  • Patrick Michaels
    Patrick Michaels May 05, 2008
    that installation instruction is no longer available through that link, and usually only refers to countertop installation
  • 2,336 Answers
You will find the installation instructions by clicking here.
  • Jaime Hernandez May 05, 2008
    You can check this link for a detailed info on how to install the microwave and the ventilation needed.
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
JES1290SK No power when on. Display works, work light works until enter is pushed. No motor movement
Does the convection work? If so likely you need a magnetron If the control panel is having problems then it needs to be repaired or replaced. It could be just a stuck relay inside so a firm hit may release it
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Removing the cover on a Whirlpool Microwave Model MA1170XSS-0
You may find it has security type bolts that require a special bit, take a good look to see what the bolts that secure the cover look like.
Nov 05, 2012 | Whirlpool Microwave Ovens
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
I'm trying to remove but unable to determine how
most over the range micos are secured by either 2 or 4 screws from above usually inside a cabinet or storage above remove those disconnect or pull away venting if vents above,, u willl need two people sometimes to help hold micro..... i would have to see the unit some might also have trim pieces if its more of a built in situation hope this helps
Jan 31, 2010 | Panasonic Microwave Ovens
I need the glass turn table asap. and how much does it cost? for jes1290sk
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=WB49X10174&productGroupId=0022&supplierId=364&brandId=0432&documentId=G0606370&keySuffixId=NA&modelNumber=JES1290SK02&keyId=1508&pageId=00001&productTypeId=0123245&searchModelNumber=JES1290SK02&subCompDesc=Microwave&brandDesc=GE&modelDesc=MICROWAVE&blt=11
Unless you can find one someplace else cheaper.
Eric
Dec 11, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Dec 05, 2009 | Samsung Microwave Ovens
Venting
If this microwave has vented outside in the past then most likely a bird or something has built i nest in or on the vent blocking airflow. If its always been this way then in order for this model to vent though an exterior duct the blower motor has to be flipped so that it blows upwards and a vent connector needs to be installed. This is a fairly easy process once the microwave has been taken down but can be dangerous because there is a capacitor that holds 4000 volts that can discharge though the cabinet if you're not careful.
Nov 03, 2008 | Jenn-Air JMV8208AAS Microwave Oven
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Aug 12, 2008 | GE Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
