Unable to run cd rom - Computers & Internet
    Genius:
  • 2,785 Answers
Clean with lens cleaner otherwise you hve to replace with new one
Posted on May 05, 2008
PC turns on but will not boot up; unable to run directly from cd rom
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
I have had an LG dvd burner(GH22NP20) for quite a while now, recently it has been unable to read any cd-roms. It reads dvd-roms though..... It will load cd-roms outside of windows so I know the drive is...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 26, 2011 | LG 22x8x22x DVD?±RW DL IDE Drive Black...
Unable to open cd rom drive
check the power cable at the back. Your cd player could be malfunctioning. Try using a paper-clip wire and insert into the small hole in the front to open the tray.
Jul 18, 2010 | Intel Motherboard
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
I am unable to get system restore to run properly highest indicator reading before stopping was 60%
It is either one of two things.
1. Your cd is scratched, try wipeing it off real good and running it again.
or
2. Your cd-rom is messed up, try swapping cd rom drives.
Jun 13, 2009 | Computers & Internet
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
Unable to burn dvd using LG DVD ROM
your DVD Rom drive cannot burn DVDs because it is not a DVD burner, DVD Rom drives are different from DVD writers, if you want to burn DVD you must buy a DVD burner/writer.
Jan 10, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Vista no longer recognizes my CD-ROM
"...manual driver update..." ... from the device's included driver disk? Or from a web-source? If web-source, how long ago and from where?
"...it found the hardware but was still unable to load driver software..." ... So Windows does recognize it then? Unable to load what .. the driver(s)?
"...Vista just isn't recognizeing my CD-ROM at all" ... ??? If I understand correctly, Windows "device manager" recognizes when its deleted, then refreshed, but Vista doesn't recognize it? By this do you mean it's icon does not show up in "My Computer"?
Lot of questions I know, but it's necessary to define the trouble in order to know which direction to go next.
ASSUMING IT'S RECOGNIZED BY YOUR WINDOWS VISTA OPERATING SYSTEM:
Here are a couple of very helpful and comprehensive software diagnostic tools for you to download at http://www.cdspeed2000.com/download.html. They are both FREEWARE and the same tools licensed to Nero for inclusion in their software products.
Installation: Simply extract/unzip the file to any chosen directory and run the executable (*.EXE).
1. "Nero DiscSpeed". Thoroughly tests speed and performance of your optical drives(s).
Download: http://www.cdspeed2000.com/files/NeroDiscSpeed_41140.zip
- Refer to the program's Help for guidance.
- User guide also available at http://club.cdfreaks.com/showthread.php?t=192563
- Here's a quick shorthand:
a. File > Options > Standard Tests > Choose which tests you wish to run (if unsure, use the default settings), then "OK"
b. Click "Start"
2. "Nero DriveSpeed". Adjust/control your drive's spin /up/down times and noise levels.
Download: http://www.cdspeed2000.com/files/NeroDriveSpeed_300.zip
ASSUMING IT'S NOT:
You need to get the latest and best driver package, then re-install. If you can provide the make/model/series of the drive, I can provide you with a reliable source to download.
Please report back, and in all likelyhood we'll get you some joy.
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
