I bought a used Okidata C6150 printer, which I just found out has an administrator password on it. How do I reset that to get around it?
5 Suggested Answers
  • 169 Answers
SOURCE: Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: i want to change the ip address on an okidata printer b4400.
Try the default username of admin and the default password of - OkiLAN and the password is supposed to be case sensitive. Let me know if that helps and good luck.
Posted on Mar 18, 2009
komguy
  • 2306 Answers
SOURCE: Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Posted on Jul 03, 2009
SOURCE: How to add memory to the Okidata C6150
[1] Open the top cover. [2] Open the front door. To do this, look directly under the digital display and located a latch. Pull the latch up and the front door will open toward you. [3] On the right-side panel of the printer, locate a big screw in the middle of the top and loosen it. Now, the side panel comes off easily. [4] Once the side panel is off the printer, you will see a big vertical opening where one (1) RAM module can be inserted. [5] Note also that, to the left of the big opening, the word HDD is stamped onto the metal. That's where a 2.5-inch hard drive can be installed. There are two screw holes diagonally where a hard drive should be installed.
Posted on Mar 24, 2010
How to reset pass word for window xp
A lot of times Windows XP installations do you have a password set for the administrator account. When you first boot up the machine, instead of trying your username and password, try using the username "Administrator" with a blank password. If that works you can go to the control panel and reset the password for your user account.
Otherwise you can try using the offline NT registry editor. A great video showing its use can be found here. You can also use OPHCrack found here. Both of this have a slight risk for data loss so proceed with caution if you choose to that route. If you have any further questions about the process, let me know.
Oct 13, 2012 | Canon ImageCLASS D1120 All-In-One Laser...
Hi everyone, I have just bought an OKIDATA MC361 and changed the administrator password. I have copied it from an excel sheet, but when I want to login with this password, it can't.. So there must have...
How To:
Reset the admin password on the unit. Action:
Follow these steps to reset the password:
1) Go into settings -
2) Press the following, on the number keypad: # 0 1 0 3 *
3) The printer will ask for a password, the password is 000000
4) Once in the maintenance menu, go to System Maintenance -> Reset Admin Password -> Execute -> Yes
5) This will reset the password.
Mar 30, 2011 | Office Equipment & Supplies
Hi we have a okidata b930n whit the " panel locked " error we can't use the panel control. thanks
Panel locked message is set to prevent changes in the unit. Your IT person probably locked it. You may need a password to remove the lock. Neither manual gives a reset method.
See page 147 in the reference manual:
http://www.softcom.cz/Files/00067013-00488709.pdf
User Guide:
http://www.ta.cz/common/download/OKI_N_B930_ENG.pdf
You may have to call or email Okidata:
www.okiprintingsolutions.com/us support@okidata.com 1-800-OKI-DATA
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2010 | Office Equipment & Supplies
How do I reset administrator password
click start
control panel
switch to classic view
click user accounts
then click computer administrator
change password
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
How to reset black toner for oki c6150
Greetings,
try this In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
Regards,
TechSup1
Apr 30, 2009 | OKI C5100n Laser Printer
I want to change the ip address on an okidata printer b4400.
Mar 18, 2009 | OKI B4400 Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
Mac-Compatible Impact Printer???
Okidata works pretty good for 4 part forms. I've worked on dot matrix printers in the past and found that a lot of them jam with that big of a form and eventually burn the motor out a lot faster. Not a problem to handle on an Okidata.
I have yet to find a USB interface for one so that might be a challenge. Apple used to use a round serial interface. You might be able to find a workaround for that using a USB hub. I have a Belkin one at home that carries an Apple serial interface.
Another idea that could work is to use a parallel based print server with a eternet port on it. Then you can run it on a TCP/IP. The only time you need to use a browser is for administration setup on the print server by typing in the TCP/IP address into the browser.
Safari can work in place of Firefox. Make sure the printer server has Mac drivers for it.
Oct 30, 2008 | Office Equipment & Supplies
677 people viewed this question
k24674
jasbo
jasbo
