Question about Samsung HT-X40 System
It keeps going to protection mode and shutting off
  • 104 Answers
Sounds like Something is hooked up backwards or voltage is wrong and it's over heating
1. make sure all the speaker pos/neg connections are attached properly as instructed.
2. make sure all voltage selector is set to 120V not 220v
3. try playing with no speakers and add just one speaker at a time (power off with each addition)
4. check the fan on the PSC (printed circuit board) - inherant problem
5. if the above don't work and it's under warranty return it immediately for a replacement
6. if not make sure cooling fan is working and dust free - sometimes flipping or turning it around does the trick this is a design flaw
Posted on Aug 24, 2010
  • deathmetal73 Aug 27, 2010
    I'm kinda having the same problem. My unit is just shutting off after 10-30 mins of use, I just took the case off the receiver
  • Glenn514 Oct 03, 2010
    I connected a HDMI cable to my TV set hence no speakers issues. Yes it's set at 120 v and it's dust free (brand new). The issue is that it turns on, diagnoses itself, flashes PROT then shuts down (within 5 seconds of boot). Can even reset to factory settings. Conclusion: set it dead. Awaiting replacement.
2 Suggested Answers
SOURCE: i have sony avd-k800p and it keeps going on
I am having Sony HTD-C800DP Home Theatre system. I would like to know how to play DIVIX DVDs. I couldnt successful. Any one of you please help me in this. Kindly send information to my e-mail id thayumanavan@yahoo.com
Thanks in advance.
Regards,
Thayu
Posted on Nov 10, 2010
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
I keep losing power to my sub
you need to be more specific, is the amp going into protect mode or getting hot or shutting off? How many subs are hooked up and how , meaning amp is in mono or stereo mode? How long does ut take before it happens?
Aug 06, 2013 | Car Audio & Video
Tv keep shutting off
ur set is going in protection mode required repair work
Oct 10, 2012 | Insignia Televison & Video
Shuts down in protect mode
disconnect all the speakers and turn it on. if it does not go into protect mode, then youve got a bad speaker or wire. good luck
Feb 10, 2010 | Sony STR-DE597 Receiver
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
8001 Receiver keeps going into protect mode. What
Fastest way to check the receiver is to disconnect all speaker wires at the receiver and turn the unit back on. If it does not go into protect, your receiver is ok and you need to check all wires and speakers. If just one piece of braid on a speaker wire touches the other, it may not shut off immediately, however, as you turn up the volume the current level rises in the wire and creates a short. Thus, shuts down the receiver. If you need further help troubleshooting, post a comment and I can walk you thru it. Hope this helps.
Aug 16, 2009 | Audio Players & Recorders
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
May 15, 2008 | Audio Players & Recorders
Samsung HT-X40 System Logo
1,181 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
