Question about Mitsubishi WD-57733 57" HDTV
My tv is making a popping sound and the sound is cutting out and the screen goes blank for a few seconds. the picture doesn't seem to be as good as it was. we probably need to change the bulb, but don't understand the sound problem.
  • Mitsubishi Master
  • 5,568 Answers
Both problems can be caused by a failing solder joint in the main power supply; you may not need a bulb yet. <div><br /></div> <div>The supply may be on a separate board, fairly easy to remove. If you or a friend has a <i>quality</i> soldering iron or station, you might unplug the power supply board and visually inspect (with magnification) and look for a solder joint that looks rough or is cracked (it happens), use fresh resin core solder and reflow any suspicious soler points. </div> <div><br /></div> <div>If you are concerned about getting the supply reconnected, take a couple of snapshots of the wiring to and from it before disconnecting.</div> <div>The plugs are normally all different so tough to interchange by accident.</div>
Posted on Aug 24, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
When i hook my wii up to it doesn't pop up but you hear the music playing in the background
It seems to be a compatibility problem. Check both operation manuals and follow instructions contained there.
Jul 18, 2012 | JVC 42 in. LCD TV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Picture goes in and out
Yes it sounds very much like it is simply in need of a tuning. Also if you do not feel comfortable repairing yourself, this is a very simple fix that can be done at most any electrical repair shop and usually doesn't cost too much.
Jan 19, 2008 | Sony SLV-D570H DVD Player / VCR Combo
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi WD-57733 57" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
