Question about GE JGP975SEKSS Stainless Steel Gas Cooktop
The buzzer for the safety lock will ot turn off. It should only sound when gas is turned on when locked. Now it sounds wether any burner is on or off. i had to throw the breaker to shut it up. Does anyone know how this should be troubleshot? It appears this switch has to be accessed from underneith.
TheMobilian
  • 8220 Answers
SOURCE: ignitors keep making ticking sound, all burners
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Posted on Jul 17, 2009
SRF518
  • 232 Answers
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Posted on Oct 17, 2009
Testimonial: "Thank you so much I followed your instructions...I think the problem was in the knob as you said...Thanks again!1"
milten1
  • 1304 Answers
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
  • 113 Answers
SOURCE: i have ge jgp337 .
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Posted on Aug 15, 2010
heatman101
  • 43501 Answers
SOURCE: How to diagnose, remove and replace spark module
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
Pilot lock light on stove is on so stove burners unable to work
This sounds like you may have to fix a problem in the pilot area before it will work. These gas operated devices have to meet a much higher safety standard than their electric counterparts. It is a built- in safety feature. Now, look for any obstruction or crimp in the gas line. My guess is you are not getting proper gas flow or pressure or the pilot could be physically blocked.
Feb 19, 2015 | Thermador Cooktops
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
Jul 19, 2011 | GE Profile JGP636 Gas Cooktop
Turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 12, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
Cooktops Logo
52 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
