Question about Motorola Mobility H350 Wireless Headset
WHERE DO I PUT MY PASSKEY IN @ - Motorola Mobility H350 Wireless Headset
    President:
  • 1,118 Answers
You should enter '0000' (four zeros) on the blueteooth enabled device (e.g. phone, computer, etc.) you are trying to pair your headset to.
Please, let me know if you need further informations.
Regards, Carlos
Posted on Aug 24, 2010
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
Aug 04, 2013 | Computers & Internet
Car shut down and security light is blinking
Try doing a Passkey security system reset (procedure below), if that is not successful then you will need the dealer to scan the VATS module with controls the security system.
PASSKEY LOCKOUT RESET ALL GM CARS 1999 AND UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the PASSKEY system to recognize your key.
May 10, 2011 | 2000 Pontiac Bonneville
Lost manual in need to pair in put in a passkey in for use
The passkey is 0000 :).
Please rate this is it has been helpful!
Mar 07, 2011 | Eforcity Motorola Bluetooth Headset H500...
How to put the headset into pairing mode, and the passkey?
press and hold the power button until the light on the headset flashes rapidly, it is now in pairing mode, the default passkey is usually 0000
Nov 24, 2010 | Motorola Mobility H371 Bluetooth Headset
Jabra bt2050 passkey 0000 dosent work with pairing my blackberry is there an alternate passkey i can use
Try putting in 1111. It still will not engage. But after you do this it will reset. Then put the 0000 in and you will be connected.
Sep 06, 2010 | Jabra BT2050 Bluetooth Headset
I have an iphone I have switch Bluetooth but can
usually the device or the iphone will prompt you with the passkey when trying to pair.
ie. start the connection process, the device says here is the passkey, the iphone will show a menu to put in the key, type it in, the devices pair up.
Jul 08, 2009 | Apple iPhone 3G
Need passkey number to connect bluetooth to blackberry
Usually they're 0000. You may have to hold down the answer button as you turn it on, or hold it down for 10 seconds to put the device into pairing mode. Check the manufacturer's manual for more specifics.
Dec 15, 2008 | Motorola Mobility H500 Headset
Motorola Mobility H350 Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
