Question about Brother DCP-7020 All-In-One Laser Printer
A message "Low Toner" will appear after each print job. The printer will not print again until it is shut off and restarted.
    Problem Solver:
  • 11 Answers
I am assuming that the toner (what they call ink in a laser printer) has been replaced and isn't actually low. Try and remove the toner cartridge and shake it side to side gently. Reinstall the toner and see if this helps. Unfortuneatly the next step is to buy a new toner and see if this fixes the issue. If it does then you know the toner was bad. Always try to use Brother brand toners and not generics, you will have more consistent results. There is a copy of the user manual here: http://www.google.com/url?sa=t&source=web&cd=3&ved=0CBwQFjAC&url=http%3A%2F%2Fcontent.etilize.com%2FUser-Manual%2F10368916.pdf&ei=DRtzTKGaK4y-sAOb68CgDQ&usg=AFQjCNFDk8vSMdw6llJHSObhadxddcG_Ow
Posted on Aug 24, 2010
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
Hi, just replaced my toner on the MFC-7220 and a message Toner Life End is displayed and will not print. I have tried 2 brand new toner cartridges. Thanks, Linda
Hi there !
Try this solution if it works, the memory of your printer still programs that your toner is end.
Try to make hard reset of your printer by turning off your printer for 5-10 mins, unplug the power cord as well and remove the cartridge toner. Then return back the cartridge, plug the power cord and then restart your printer. Then try to print again.
If displaying still this message, just press stop button to remove the message.
Also, if there is wiper for cleaning the toner cartridge everytime your put new toner, please do it.
This is what we do in your bother MFC printer when this message appears. Just restart the printer and keep pressing stop button when the printer starts.
I hope it helps you. Regards.
Jan 31, 2011 | Brother MFC-7220 All-In-One Laser Printer
I am trying to print from my netbook using an hp printer. i am getting an error message saying that the print queue is full.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong.
Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up.
To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Dec 06, 2009 | Office Equipment & Supplies
Fax waiting message on dell 1600n. will not print why?
This usually isn't a driver problem. Mine won't print-out a fax when toner is low - at what point is low, I don't know. To solve, go to Menu button and press until 4. Fax Feature is displayed. Press Left - Right button until 'Ignore Toner' is displayed and press Select button. Press Left - Right button until 'Ignore Toner - On' is displayed and press Select button. The unit will then print 'Fax Waiting' pages.
Sep 03, 2009 | Dell 1600n All-In-One Laser Printer
Toner Low And it is not printing
Have you changed the affected toner? Most printers will stop printing when one toner is showing empty.
Jun 23, 2009 | HP Color LaserJet 3500 Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Unable to Print error
try resetting the print jobs from your computer printer que and also resetting all jobs from the printer side also good luck
Nov 08, 2008 | Ricoh Aficio SP-C210SF Printer
Printing in grayscale
yes u can use it with black and white
Nov 01, 2008 | Dell 3010cn Laser Printer
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
