Question about Samsung HLP4663W 46" Rear Projection HDTV
The TV screen starts to flutter and the colors start to change, yesterday it kepr getting darker and darker tilll you could hardly see the picture
  • Samsung Master
  • 12,061 Answers
Http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010300&model_name=HL-P4663W
Above is your diagnostic link for your TV, below is your user manual.
http://www.retrevo.com/support/Samsung-HL-P4663W-TVs-manual/id/276bh042/t/2/
below is your training manual for you.
www.scribd.com/.../Samsung-Lcd-Lb350-650-Training-Book
Service and repair manual below.
http://www.eserviceinfo.com/index.php? what=search2&searchstring=samsung+hl-p4663w
it is my professional opinion though that everyone should take their units to their manufacturers approved service center, contacting a head office, of your unit & getting an approved service center is just SO important, even worth the extra to ship it, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". This way, at least, you'll know weather to repair or replace.
Most likely it will be your color wheel,or Tube, one simply must troubleshoot if DIYing as many symptoms appear the same but are not.
Posted on Aug 24, 2010
Picture flutters
If this is a projection TV and it shrinks and expands its a common issue with certain Philips TV sets. Sites like www.TvRepairKits.com have the kits to fix this.
Mar 30, 2012 | Televison & Video
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba 27A45 picture and colors began to get darker and darker until whole screen is black. Sound still good. After a minute or two the picture returns fast.
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor
Jun 07, 2011 | Toshiba 27A45 27" TV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Plasma HD TV Picture blue color static
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
PT-47WX42 47 - Red color becomes prominent and screen goes blank when changing channels
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 20, 2017 | Panasonic PT-47WX42 47" Rear Projection...
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
