Question about Toshiba Satellite A60 Notebook
My Toshiba Laptop Satellite L500-02H is failling too much, first it didn't turn on, later on it turned on but the screen was only black, then I tried again and it loaded untill the part where you put the password when I put the password it stopped with the message of "Welcome", and then I tried again and it loaded correctly BUT when I tried to open a folder or even click the START icon it stop working, it keeps freezing and I don't know what else to do, can someone help me please?
5 Suggested Answers
  • 404 Answers
SOURCE: toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Posted on Dec 09, 2008
  • 243 Answers
SOURCE: hi, i have stayed my
try to enter the system using safe mode by entering f8 when you turn on the laptop, log on as administrator and try to restore your laptop to an earlier time, go to all program accessories, system tools, system restore..
Posted on May 09, 2011
  • 367 Answers
SOURCE: my toshiba l500-02h is only
Hello, Does it sit there and do nothing? Sometimes all that is needed is the battery pulled (disconnect power cord as well) Press and hold the power button down for about 5 seconds. Put battery back in and connect power cord. Now try booting. If nothing shows on the screen, the next step would be to connect an external monitor or TV (if you have one) to the VGA or HDMI port. If a picture shows on the monitor / TV but still not on the laptop, you may have a burnt out display... which is expensive to fix. You may find some good prices for screens on dbay.
Posted on May 11, 2011
SOURCE: Satellite L500 monitor is completely
Try to go to Toshiba Power Settings in the control panel and change the lcd brightness from there. If this won't work, this may be an LCD backlight issue and you would need to have a professional to change it for you. If it is under warranty, send it to toshiba for replacement.
Hope this helps.
Posted on May 30, 2011
Toshiba Satellite P505D-S8000 black screen
have you changed all cables, is there power gettint to unit? could be bad lcd or inverter
Feb 09, 2013 | Toshiba Satellite P505D-S8000 18.4"...
Hi, i have stayed my laptop for hours then i closed it. I tried to open it again but my laptop password icon didn't appear anymore thats why i cant open my laptop. I tried to restart, it opened but the...
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
I replaced my screen on a toshiba L35 laptop and turned it on screen is black now comp is running . help please?
try first your laptop without using your laptop screen. remove laptop screen and testing display output from your CRT or LCD monitor. if display comes out, try to check your inverter.
Feb 04, 2011 | Toshiba Satellite L35-S2366 Notebook
Black screen if electrical cord is plugged into my Toshiba
Power options is most likely where you need to look to fix this. Go to the Control Panel and search for Power Options then change plan settings.
On a laptop, you will see that there are different options when you are plugged in versus running on battery.
Check your settings for blanking the screen when you are plugged in, that's probably where you will find the problem, set it for at least an hour before it blanks the screen.
Oct 02, 2017 | Toshiba Satellite P305D-S8900 Notebook
Blank screen
Take a flashlight and shine it on the screen. If you can see an image, you probably need to replace the power inverter board. It supplies power to the backlight.
Jan 23, 2010 | Toshiba Satellite M305D Notebook
Laptop turns on for 5 secs then turns itself off. The Toshiba screen appears and 2 secs later turns completely off. Is this a virus or some other issue?
sound like power supply or battery. first try running the laptop on battrey if the problem persists, then pull battry and try running on Power Supply only. if problem is fixed then your battery has gone bad.
Oct 12, 2009 | Toshiba Satellite A135-S2276 Notebook
Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Mar 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Jan 31, 2009 | Toshiba Satellite A215-S7422 Notebook
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
My toshiba laptop keeps freezing unexpectadly
Whats causing my Toshiba Satellite U205-S5002 laptop to keep freezing? Need assistance on how to troubleshoot the problem.
Oct 24, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A60 Notebook Logo
279 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
