Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Frigidaire Gallery Model GLET1041AS1. No water will fill into the tub. The unit has power, and when you turn the knob to a cycle, the tub spins and works fine, just nothing happpens when you start the washer.
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 4 Answers
SOURCE: Front loader will not spin
Might be a burned (a few coils) motor - feel any burned paint smell?
Alternatively, a broken belt - you'd hear rthe motor spinning, though - or some sensor/wiring malfunction.
Posted on Jan 14, 2008
  • 240 Answers
SOURCE: Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Posted on Apr 23, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
Posted on May 27, 2008
SOURCE: frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Posted on Nov 02, 2008
The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
May 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Cycle will not advance
ok turn off unit at power switch, turn knob to drain and spin, and turn back on that will reset its programming and force it to do the drain and spin cycle also check the drainage hose to ensure it's not kinked or clogged. If it's clear and in good shape
Jun 29, 2009 | Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Washert not draining
If your washer spins but doesn't pump the water out, the drain line might be clogged.  In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. You already have replaced the pump motor and still no operation,  so check the power voltage to the pump during the drain cycle.   Verify the problem is not pump related as much as power to the pump being the problem.
Mar 15, 2009 | Frigidaire FWS445RF
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer only stays on rinse cycle
The first thing to check in a no-spin condition on any washer is the lid switch. The whole purpose of the lid switch is to stop the tub from spinning when the lid is opened and this should also cause it not to drain or fill. It’s a safety thing.
A quick check of the lid switch is to slowly raise and lower the lid a little bit and listen for a faint clicking sound. This is usually a pretty good indication that the lid switch is working but it’s not definitive. A better test is to put an ohm meter on it and test the switch. You can access the switch by removing the washer cabinet.
The lid switch will most likely look like one of the two pictures below. You can click the pictures for a larger view and to order the part.
Older-style Lid Switch
00094434.jpg Newer-style Lid Switch
May 06, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Water filling tub on washer
First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
Jan 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
