Question about Singer 7436 - INGENUITY
Cant get bobin casing back into machine - Singer 7436 - INGENUITY
    Genius:
  • 1,788 Answers
You gone online to www.singerco.com and get the manual, it is free to download. Their customer service is terrific and can talk you through it, if need be. Their number is in their website,
Posted on Aug 24, 2010
Need to know how to put bobin case back together
Go grab that many by the ear and drag him back in there and make him put it back together.
or... use this as an excuse to go buy a seriously expensive new sewing machine.
Nov 16, 2012 | Sewing Machines
Pfaff creative 2134.....needle is hitting the bobbin casing
There is two possible solutions. either the machine has been knocked out of time by a thread jam or the needle rod has been bent. Good Luck!
Apr 19, 2011 | PfaFF Sewing Machines
My problem is with the bobin. The machine worked well two days ago. Now when I try to sew , the bobin thread is becoming caught in the lower area and produces tension that stops the machine after about two...
With out looking at the machine it is hard to determine the exact problem, but make sure your bobbin thread is placed in the bobbine case corretly, and pulled through the little tension area on the bobbin case.
Next make sure the upper thread is in the tension discs, if not this can also cause you a problem, plus if possible used a little canned air (with the pressure foot up, machine unplugged and thread removed) blow out the tension area.
Good luck.
Mar 12, 2011 | Brother SE350 Mechanical Sewing Machine
I took out the bobin case and now when I put it back in it wont stay. The thread bunches up or the bobin case comes out of place. Any idea on how to get it to stay put?
The manual usually shows a pretty good diagram of how it should be, it snaps in place. Call singer at 1-800-4singer. Or go online at singerco.com and download a manual for free,
Sep 09, 2010 | Singer 5050 Mechanical Sewing Machine
The uper thread dose not catch the bottom thread
If there is a screw on the side of bobbin case try tightening it up.This usually worked on my old machine.
Sep 18, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
My Singer 2639 Bobbin case pops up out of position after few stitches and needle hits case, Singer says it needs retiming and take it to repair. I cannot continue paying repair as this happens too often.
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Sep 03, 2008 | Singer 7462 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Bobin casing
Look in the bobbin area to see where the screw fell out. Check your manual. Sometimes they have a good picture of the bobbin area.
May 05, 2008 | Necchi 3537 Mechanical Sewing Machine
Singer 7436 - INGENUITY Logo
18 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
