Question about Yamaha HTR-5830 Receiver
Front speakers have no sound now.
A few years ago, I bought HTR-5830. It had been working well until several months ago. Suddenly, there was no sound any more. Today, I follow the manual to test all speakers, two rears, one central, and woofer are working properly. Only the two front ones have no sound. I think that the speakers are not working. So, I switch the front speakers with the rear ones. When these speakers are switched to back walls, they do work.
Then, I check the wires, pull them out and insert them in. Unfortunately, there are still no sound in the speakers on the front wall.
What went wrong? Any help will be greatly appreciated. My email is: jshi57@yahoo.com
  • beth879 Jul 23, 2008
    I have the same problem with the front speakers. We had a Kenwood receiver before this and the same thing happened, that's why we bought this receiver. What's up with this? Is it a common problem for the receiver's channels to go out on the front speakers?!? Help!
  • Nuihc88 Aug 01, 2008
    I've had this same problem for a few days now and nothing seems to help. I've: reinstalled drivers, tried different sound cards (all have the same problem), speakers (all working) and operating systems (Windows XP & Linux Ubuntu), restored BIOS to save defaults...
    I had the same exact PC setup working fine until i moved the motherboard to a different box. I have the same wires and jumpers connected the same way as earlier, PCI devices & most USB devices as well.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
Posted on Aug 01, 2008
What gauge speaker wire does a yamaha HTR-5830 use?
I dont think you can get much larger than 12 gauge wire into the speaker terminals
Feb 28, 2013 | Yamaha HTR-5830 Receiver
Can I hook up wireless speakers to Yamaha HTR-5830?
there are wireless kits available, and most all yamahas have pre-amp outputs for all the channels
Cant get front left and right speakers to produce sound....when i try to use the receiver remote to turn up the decibals on the front speakers it wont go past "0"...it will go into the negatives...
1. Speaker B instead of A selected??? Page 53.
2. As far as the Fronts limiting to 0 dB, they are the reference for all others. Perhaps the engineers thought it made no sense for the stake in the ground to have a moving reference level. See step 3 on Page 50.
http://www.retrevo.com/support/Yamaha-HTR-5830-Receivers-manual/id/394ci070/t/2/
Jan 22, 2011 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Front left and right speakers don't put out sound
Hit the button  "speakers/a/b/off" on the left hand side of the front panel until it shows that "speakers b"  are turned on.
Jan 11, 2009 | Yamaha HTR-6130 Receiver
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Yamaha HTR-5830 Receiver Logo
236 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
