Question about Homelite Blower Frame Up04405 Up04405a Bp250 Backpacker
I have a Homelite BX 90 blower. The pull cord came out and I would like to know how to repair it, thanks.
4 Suggested Answers
bbreton
  • 437 Answers
SOURCE: BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Posted on Oct 14, 2009
rwvanlue
  • 486 Answers
SOURCE: i pulled the cord off my homelite 2 cycle leaf
Yes,
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
  • 130 Answers
SOURCE: Homelite bandit bx 90,
On the bandit, you are safe with a 40:1 ratio. In other words 8oz. of oil to 2.5 gallons of fuel.
Posted on Feb 12, 2011
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
Have Homelite Yard Broom II UT08514. Fuel filter fell out of tank when I dumped old gas! Which little black tube (way back in the tank) does it belong on and how do I reconnect it? thanks
I have a GBI 22"v leaf blower anyway i replace a pull cord on blower but dosen't pull cusae it hard to pull i took everything apart again and again and still hard to pull the cord ok help me pelase.
Dec 18, 2011 | Garden
Homelite bandit bx 90, What is the fuel mixture?? Thanks
Feb 12, 2011 | Homelite 'Yard Broom' Leaf Blower
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Need to replace pull cord on homelite z830sb
Start from the bottom and work your way up. This is not an easy repair. You have to almost completely dissassemble the entire blower to replace the cord. You will need a T20 and T25 torx tool, a 9/16' wrench or socket, 40" of #3.5 rope and about an hour. A repair shop will typically charge $20 to $40 in labor for this repair.
Jul 24, 2010 | Homelite Consumer Products MightyLite...
I just bought a used bx-90 bandit and it runs great. The problem is that fuel oozes up thruthe top of the fuel tank right where the fuel line goes in. It runs down the side of the tank and all over...
Just replace the fuel lines they become hard and shrink allowing leakage. If your tank is like upper the part number is HM-0745499 or like lower part number HM-UP03825 or you can take to local small engine dealer and he will probably change cheaper than you can buy.
Nov 09, 2017 | Homelite 'Yard Broom' Leaf Blower
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
The pull start cord broke I live in Seattle any repair places?
Hello. This is a common problem and any lawn mower place will be able to repair this for you.
Jul 27, 2009 | Homelite Consumer Products Backpack...
Will not start
Homelite leaf blowers that use whats called a half crankshaft system are prone to many problems. Whats a half crank system you ask? If there is a small aluminum plate that attaches to the side of the engine by the gas tank you have one of these. Usually held on with 4 small bolts. I just got rid of a Homelite Vac Attack 2 that had spark and compression but the compression checked low about 75 should be 90 or better. What happened, a head bolt came loose and the engine ran lean causing the fragile rings on the piston to heat up and when that happens they loose their outward spring that seals against the cyclinder walls. A simple compression check using a gauge and not your finger will tell you that. Other causes could be less than normal spark, or maybe the exhaust port under the muffler has carbon build up or the muffler is plugged up also Check all bolts, and nuts to make sure they are tight.
Glenn
St. Paul, MN
Apr 15, 2009 | Homelite Consumer Products MightyLite...
Homelite Blower Frame  Up04405 Up04405a Bp250 Backpacker Logo
147 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
