Question about Maytag Dryers
Squeeking noise when drum is turning - Maytag Dryers
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Aug 24, 2010
  • 10,319 Answers
The bearing in the idler pulley is doing that
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
SCREECHING DRYER
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Apr 11, 2014 | Frigidaire Washing Machines
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Dryer makes a squeeking,or "chirping" noise while
Most likely the problem is the drum rollers are in need of lubrication.
Lube the drum rollers and this should solve your noise problem
Jan 05, 2011 | Maytag MDE9700AYM Electric Dryer
When I turn on the dryer it makes a sqealing noise. Belts seem ok.
there are wheels that hold the drum in place they have berrings that tend to go bad i would replace them it should fix the squeek. also you can put some bar soap aon the beld to quite the squeek if it is not the holding wheels
Jul 21, 2009 | Whirlpool LER5636P Electric Dryer
Ge dryer squeeking
HI,
For a pictorial troubleshooting please open the link:
http://www.applianceaid.com/my_own_dryer.html
You will be looking at the front glides that the drum rides on, the glides are probably gone and the drum is rubbing on the plastic glide holder....if it is damaged will need to replace the front drum bearing/glide holder and all of the glides, usually about 4 of them.
If it is the drum front glides the noise will be from the front area, right behind the front panel at the top. If the noise is from the center rear of the dryer your drum bearing is gone, need to replace this also if you have to take this dryer apart..
Thanks
Apr 08, 2009 | GE Dryers
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Squeeking noise from drum when drying
Bit of a long shot, but I once had a machine with a crack at the root of one of the spokes on the big pulley wheel on the end of the drum - made a nasty noise once every turn as the belt tension came on and off that spoke. Good indicator of this would be if you can make the squeak happen when you turn the drum by hand, but this stops when you take the drive belt off. If the noise is still there with the belt off, try removing the hose that leads from the base of the drum to the pump and use the hole that leaves to try and find if anything (stray bra wire?) has got stuck between inner and fixed drums. Check for the same thing between the front edge of the drum and the back of the door seal. On some machines, you can also get a little access where the condenser plugs into the back of the drum. Finally, give the pulley wheel a good shoogle up/down, left/right and back & forth to check the bearings are OK (another long shot). A
Feb 20, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
