Question about Canon PowerShot SD1000 Digital Camera
Software loading error
When I try to load it, the following error appears: "The screen resolution to execute Digital Camera Solution Disk is not sufficient."
So I went to my control panel, display and tried to increase the setting 800 X 600, highest 32 bit. It won't increase.
This is an older computer 2003 with XP. Is that the problem -- a video card or something inadequate? Thanks
Posted on May 15, 2008
Trying to install software for Canon Powershot A640 on a Acer Aspire One Netbook. Receive error message "The screen resolution to execute Digital Camera Solution Disk is not sufficient."
Skip the installing of any software, unless you like the Canon editing or viewing software, if that is on the cd.
Get a card reader for this machine, and skip any drivers whatsoever.
By using a card reader/writer it is not necessary to get any software or drivers on your machine from Canon. The card reader will read as another drive.
Apr 12, 2010 | Canon PowerShot SD1000 Digital Camera
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
Inserted the disk for my Canon A470 into my computer. Got the message "screen resolution to execute Digital Camera Solution Disk is not sufficient." I realize it's not a camera problem but not...
You have to set the resolution on your computer's monitor to the minimum required to run the software. To do this, go to your desktop (no programs showing) and right click in an empty area on the desktop. Go down to "Properties" on the menu that appears and click on it. Look along the top of the window that opens for a tab named "Settings" and click on it. You should see an option (usually on the left) to change your screen resolution. Change your resolution to the minimum required for the program. Depending on your computer, you may be asked to confirm the new settings, or you may have to restart your computer (the computer will tell you). Once you have the new screen resolution set, things will appear to be smaller on the monitor, but you will be able to see more of whatever you are looking at.
Oct 06, 2008 | Cameras
Intalling camera software.
Greetings Shayy,
Generally screen resolution refers to your computers resolution which is controlled via the control panel of your computer. I would try fiddling with other screen resolutions to see if this helps. This will cause items on your computer to either be larger or smaller than you are used to, but you might find you like it better.
You would go to control panel>display>settings, to adjust this.
I hope this helps.
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon powershot sd850 is digital elph
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Software installation problems
You do not need software for the computer to read the camera to upload images. The supplied disc with digital cameras is best left in the box let windows do the work If you would like an images editor then downloaf Picasa which is free or invest in a full editing software such as Coral paintshop pro or one of the Serif range
Sep 16, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
352 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
