Question about Lenovo 3000 N500 Notebook
My external speakers stopped working - Lenovo 3000 N500 Notebook
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 24, 2010
My speakers have also stopped working although works perfectly with the earphones. Can this be rectified? Can it work with external speakers? I don't like using the earphones all the time
Check the speaker icon on the right bottom cornet of your computer screen
Right click on it
Choose PLAYBACK devices
SELECT the Speakers/External speakers
Right click on it and Select Set as default device option
Or right click it on and configure option > follow the on-screen instructions
Incase you do not see your external speakers then right click on empty space under PLAYBACK devices
make sure SHOW DISABLED DEVICEs option is checked
Kindly reply back if this helped or not
Jan 02, 2018 | The Computers & Internet
My lenco speaker has stopped working
If you have powered speakers and they work on other devices, such as; a pocket radio, recorder, etc.; then you need to reset the output to your speakers on the computer. Go to the lower right Icon (Speaker symbol) click on it. Go to System Sounds and see if the speakers are set correctly. If no check Marks indicate the external speakers are set, make your option set to your external speaker set.
Jan 16, 2014 | Audio Players & Recorders
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
Internal speakers just stopped working. External spealers work via headphone jack.
once you connected with the external speakers the internal speaker will never work
Feb 24, 2010 | Gateway T-6330U Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
The audio on our Nuvi 780 just quit working the maps still load and runs fine, just cannot hear anything.
did you check in the system settings, to see if the volume has been decreased or muted ?
Failing this, the speaker has stopped working, and needs replacing, unless theres a seperate external speaker socket you could use, with a headphone or external speaker.
Mike @ Compurepair.
Jun 11, 2009 | Garmin nuvi 780 GPS
Laptop internal speakers are not working...
Usually the internal speakers work when the stereo jack for external speakers if removed from the socket, so just give it a try....................sodeep
Apr 10, 2009 | HP Compaq Computer Speakers
External Speakers stopped working after installing leopard
go to control panel and find out what brand and modile your sound card is ten go to the manifactures website and download the drivers for that sound card but note unistall the sound card from the device manager first then once you have the drivers downloaded restart your computer and let windows find the driver for you if it says it cant find the driver install it manualy from the location of wich you saved that driver software you downloaded and the problem should fix itself
Feb 04, 2009 | Apple MacBook Pro Laptop Computer with...
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Lenovo 3000 N500 Notebook Logo
97 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
