Question about Fisher and Paykel GWL11 Top Load Washer
Hot water will not fill into unit. hot water is hooked up and line feels hot. ?
  • Fisher and P... Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on Aug 24, 2010
Do you know if it's a hot or cold feed at inlet
Hi Charles
The traditional method of supply was using hot water for filling. However, it is possible to save money on some machines by hooking up to cold water as the element in the dishwasher uses less power than your water heater. Unfortunately, some manufacturers still require using hot water for filling. You'll need to check your manual to see if this is the case. Here's a link to This Old House explaining dishwasher installation.
Hope this helps
-Steve
How to Install Dishwasher
Mar 04, 2015 | Dishwashers
Electric GE Water Heater Not Heating Water
One possibility: Push in the reset button located on upper thermostat.
Copy following link for troubleshoot walk-thru, and DIY checks:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Nov 04, 2012 | General Electric Water Heaters
The NF light comes on
The nF error code stands for "No Fill."
If you have just installed your washer and it will not fill, or the display shows nF, check the following:
  • Make sure the door to the unit is tightly closed.
  • Make sure that both the hot and cold water lines are connected (cold to the cold and hot to the hot)
    • Note: If you do not have a hot water source, you can hook up the cold water source to the cold input on the back of the washer and another cold water source to the hot input on the back of the washer (but NEVER a hot water source to the cold water input on the back of the washer).
Oct 14, 2012 | Samsung WF337AA Front Load Washer
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Brada washing maching keeps displaying "NF" in the middle of every load..what does this mean and how do i fix it??
NF means "No Fill".
I was getting that code too, but we only had the cold water hooked up. I hooked up the hot water and I have not received the error since. I still only wash with cold, which is strange.
Aug 10, 2010 | Washing Machines
Front load kenmore washer will not fill on rinse cycle
yes you should have both hot and cold hooked up. if that is not possible splice the line you have and y it into both inlets. thats not the best way to do it but will solve the imediate problem.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Reinstalling a washer and dryer and i know which line is hot and which one is cold coming out of the washer ing machine but i dont know which line is hot and which is cold when hooking it back up the the...
If the pipes were installed properly, then the hot is on the left, cold on right.
Hook it up that way, then set it on the smallest load possible, with hot water setting only. If you have hot water filling the basin, you have it hooked up properly.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ice maker won't fill with water
There is a soleniod near where the ice line hooks in, Take it off and clean it with hot water and soap, if that does not fix it it may be bad
Jul 31, 2009 | Frigidaire FRS26R4A Side by Side...
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Fisher and Paykel GWL11 Top Load Washer Logo
186 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
