Question about Whirlpool Washing Machines
How do i clean the pump on a whirlpool wfe1070bd front loading washing machine?
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
  • 1028 Answers
SOURCE: washing machine
bottom right corner behind the little door
Posted on Sep 27, 2008
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
SOURCE: Whirlpool AWO/D 4505 Washing Machine
The 'Clean pump' light has come on, on the above washing machine and it will not work. Any idea how to clean the pump or do I need to contact a whirlpool engineer?
Posted on Jun 27, 2010
SOURCE: My Whirlpool washing machine WFS1273AW,
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Posted on Sep 04, 2010
User manual whirlpool washing machine WFE1070BD
The model number WFE1070BD is not the complete number to look up a manual. This model seems to have been for sale in Australia, so please go to http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/ifu/home with the full code from the sticker on the washer. Enter the commercial code and then the language in which you would like to read the manual and click Search.
If you add a comment with the full code, I may be able to give you the direct link to the manual.
I hope this helps.
Oct 22, 2011 | Washing Machines
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
How do I clean the pump on my WFE1070BD front loader machine?
This also covers your question....
heatman101
Aug 17, 2010 | Whirlpool Washing Machines
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
855 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
