Question about Toys
I have a Lionel #12834 Gantry Crane the magnet quite working. All wires are intack and the controller contacts are clean. Works up and down - left and right - just can't pick anything up. There is a part that the controller wire connects to in the back of the cab that may have gone bad. I checked the turn table contacts and they both are making contact.
  • 4234 Answers
SOURCE: Peavey KB 300
Yes a horn can get blown. This should be 2 pieces, the horn itself and a circular driver on the rear. The driver itself will have what is called a diaphragm that can be removed and replaced. That is the part you want. Open up the speaker and get the part number off of the back of the horn and order the diaphragm from Peavey.
Dan
Posted on Aug 29, 2008
motor1258
  • 6674 Answers
SOURCE: LEFT TRAILER TURN SIGNAL DOES NOT WORK
I'd get a 12vdc test light if you don't have one already & start from plug, and keep probing back from there. It may be as simple as a bad connection under truck where joined into harness.
Posted on Nov 29, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: 2003 Dodge Ram 2500 diesel 4x4 wiring diagram
TPIM PROBLEM , MUST HAVE COMPUTER FLASHED AT DEALERSHIP
Posted on Jun 04, 2009
SOURCE: PIR Intruder alarm magnetic contact
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
Posted on Sep 06, 2009
How to wire No. 165 Electromagetic crane
Service diagrams are available on the Lionel web site.
Jan 23, 2016 | Crafts & Hobbies
Need to fix UJ joint on John Deere 6410 between clutch and quad range
well ph it's your choice either the engines gotta move forward or the rears gotta go back , lucky it's only gotta move 10 inches as the shaft is splined so it'll slide off
personally Id move the rear ooh and your gonna need a overhead gantry or crane to do it rated for 5 tons at least
Feb 19, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Need wiring diagram for lionel 165
Magnet is connected to one3 terminal on the rotating base of the crane and 2 the connector that presses onto the top of the spool that the line for the hook attaches to. Note when the magnet is activated, the red light in the crane cab lights up.
Nov 28, 2013 | Toys
Timer works, belt intack, i think it's the push to start
If the control looks like it has programmed but the dryer will not start, there is a thermal fuse down behind the lint filter housing. It is white and rectangular and has tow wires going to it. If it does not show continuity through it when tested with a meter, it will need to be replaced and is available below.
Thermal Fuse
Nov 24, 2013 | Whirlpool GEW9250 Electric Dryer
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Nov 18, 2008 | Lionel Cw 80 Transformer
Toys Logo
54 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
