Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell flat screen 17 in. monitor
My monitor is about 3 years old and it blinks off and on. My screen goes to black about a second then comes back and does this over and over and gets faster and faster. It is very annoying. Is there a repair that can be done or do I just need to replace the monitor? Everyone I ask gives me a different answer. One person said it is the power supply that is going out and I need to replace the whole monitor.
  • Anonymous Oct 20, 2008
    Mine only does this on a restart. The left side is darker or faded smoke gray and right side wants to light up,but shuts off after about 45 seconds. I am not sure what is wrong,but will be taking it in to have it looked at. I tore it down and I did not find anything that stood out as a problem. I feel that it is a heat related issued like a capacitor problem. I guess I will find out when I get the bill. Haha
    Novelist:
  • 77 Answers
Hi frecklesface,
Remember, when dealing with monitors, the process of elimination is the best. To elaborate this, it means, connect a similar monitor (if you can convince someone to lend you temporarily just to check if it works on your PC) if that works fine, then your monitor is faulty but if the other monitor behaves in the same manner as yours, then the fault could be in the Graphics section of your motherboard. (whether onboard or a graphics card whatever might be the case)
There is one more thing you might be missing out. Go to Display settings in your Control Panel and in that go to the Settings tag in that click on the Monitor Tag and in that check the frequency in Hertz that is selected. change that one by one and see if that helps. Only if your efforts here prove futile, then do as I told you earlier in this note.
If the monitor is found to be faulty, get it rectified by taking it to an authorised service center but if the motherboard's graphics section is faulty then ther are 2 options...
1.) If the graphics is an On-board one (which they normally are nowadays) then disable it from CMOS and add an external graphics card in either AGP or PCI (anyone you get from the market... depends on your requirements) restart and see if this helps. I feel its the best logical way it could be done.
Posted on May 05, 2008
My DELL monitor is not working I got a second
More likely to have problem in the inverter circuits, check for short between Emitter and Collector pin of the four transistors as shown in the pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My Dell 17' monitor will come on for only about 3 seconds then the screen goes black. Worked fine this morning... is there anything I can do?
you have lost the large capacitor in the power supply of the monitor (a common problem) the capacitor is a round can; it has creases in the top; the can top is flat if good, round if bad. replace it
Oct 05, 2009 | Dell E173FP 17" LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
1 year old dell monitor
Dell monitors separate 3 year warranty. call tech support at 800-8228965. have the monitor replaced.
hope this helps.
thanks.
Jan 09, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Flat Panel Monitor Logo
138 people viewed this question
Alun Cox
