Question about American Standard 3275.305.002 Colony Soft Tub Filler w/Two Acrylic Knob Ha
I have a soft tub hot tub, the control panel goes out and the temp guage registers 00 and the panel won't work. I brought it in for repair and on the test bench it worked fine. I brought it home and worked fine for about a month, then same thing, then I unpluged it and after a day it came back on and works fine.
2 Suggested Answers
  • 4 Answers
SOURCE: Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Posted on Jun 16, 2009
Temp.guage on instrament panel is erradic
Could be the temp sensor or the gauge on the dash is faulty.
Does the gauge go to cold if you disconnect the sensor ?
Jan 22, 2014 | Cars & Trucks
I have just replaced my circuit board (balboa 53247) for my eclipse hot tub and as soon as I plugged the unit in, I got an OH reading from the top-side control. Then I noticed that if I pulled the temp....
Unfortunately, I would have started with the sensors and then escalated from there. A hot tub is one of those items that I generally recommend hiring a technician to sort out, it's just flat not worth the headache of troubleshooting without the know-how.
As for your particular problem, the OH code on a Balboa control pack is "O.ver H.eating" it means that the heat sensor detected high temp and shut down to prevent damage to the system (as well as cooking you like a pink lobster) The sensor could be bad or the control board could be malfunctioning. A new sensor is $75-85 if memory serves me and is relatively easy to replace. one sensor is in the heating tube and the other is screwed into the tub shell to monitor tub temp. I would suggest new sensors, both of them because when one goes out the other usually isn't far behind. Make sure you shut the power to the tub off at the breaker box before doing any kind of tub repair. If you have shutoff valves on your tub you can replace the internal one without draining the tub. the one in the shell you need to drain to replace (at least to the sensor hole level) I hope this helps you to get your tub working properly again, if you still experience issues after this, I suggest biting the bullet and calling in a tech. Thanks for your question =)
Oct 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Temp guage not registering
Probably the sensor. I think you can test by removing the wire to the sensor and shorting to ground (with the ignition on). I believe it will show HOT when the wire is grounded. Perhaps an auto parts store can test the sensor if you take it in, or just get a new one to try. I doubt they're very expensive.
Oct 31, 2009 | 1996 Ford Escort 4 Door
Just filledd up an old dakota hot tub model126-dkn-4248-2 and ita been running for about 4 hous and wont heat up i would also like an owners manual for one but dont know were to look
it may take longer to heat to desire temp. if nothing chang have you adjust the temp higher . if everything check ok check high limit switch next to the control box ussualy red bottom push soft in
Sep 13, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Temp guage in red' dummie light on engine not hot
Sounds like a faulty sensor, if the actual temp is 195/215. The ICM is processing the information it receives from the sensor and performs accordingly. A complete diagnostic scan would be helpful in determining the proper repairs needed to correct the problem.
Good luck...i hope this helps, please rate me a fixya.
Jul 17, 2009 | 2001 Chrysler 300M
Temperture gage not working
If you unplug temp sending unit and turn ignition on check guage. It should read all the way hot or cold. If so then replace temp sending unit.
Feb 25, 2009 | 1999 Chevrolet Silverado 1500
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
American Standard 3275.305.002 Colony Soft Tub Filler w/Two Acrylic Knob Ha Logo
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
