Question about Dell Dimension 9100 PC Desktop
It will not b oot up. tried the f8 and f11 key no help
    Master:
  • 515 Answers
At what stage did the computer stop? Did you hear the sound of the fans at all? Can you see the fans of the power supply on the back of the computer turnning? If not, you may need to replace the power cord, the power supply or the power outlet on the wall. Check to make sure it is the right voltage on the back of the power supply. If the fan on the power supply is turnning, open the box and turn it on and see whether the CPU fan is turnning. If it is not, there might be something wrong with the fan, the power cable from the mother board to the fan or the mother board. You can try to replace the power cable, the CPU fan and the mother board if necessary. Sometimes the ventilation isn't so good in the box for all the dust and too many cards so CPU turned off because of overheating after running for a while. So you can try to remove the dust on the back of the box or reduce some cards if it works right after you open the box without replacing anything. Sometimes memory issue can stop your machine from booting. So replace your memory is a good try to fix it too.
Also there is a diagnose light on the front panel of the computer which will tell you the possible malfunctioning component.
You can see the detailed explanation of the signal given by the diagnostic lights on page 45 of the user manual.
http://support.dell.com/support/edocs/systems/dim9100/en/D86630LRs.pdf
You can replace the malfunctioning components to fix it too.
When booting, you can also press F12 to boot to the Utility Partition and perform a series of tests on hardware issues. That will help to find the problematic hardware for you to replace and fix it. The steps are listed in the manual too.
If your machine actually goes pass those hardware test stage and stopped with some error message on the screen, there might be an issue with your hard disk and the data if you actually boot to your hard disk. You can set boot device by entering system set up. To enter system set up, use F2 just after booting and seeing the Dell logo and the F2 prompt appears.
Then you have the option to perform a hard restore which will lose all the data for you. When you press ctrl+F11 while booting, and choose restore it will do the Dell restore which will restore your hard disk to factory default as a new one. You can see the steps on page 53 of your manual.
If you don't want to lose the data, you can back up your data by plugging the hard disk to another computer and copy the data over. You can also perform a Operating System recovery or reinstallation with your Operating System Disc and follow the steps of the Operating System manufacture documentation if you have the Windows XP CD.
Posted on Aug 24, 2010
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
When i press f8 or f11 there is no factory image restore
Are you even getting the pre-Windows Menu? Sometimes you have to try all the F keys (F1 through F12) one at a time while booting, until you find it. It is normally F2 or F8 or F11 or F12. Once you find it, select the restore option. Be warned that this will delete any documents and files you have stored. You might try the "recover to a previous date" option 1st. If the restore or the recover does not work (corrupted or missing) you will have to get the recover CD's from Dell.
Aug 07, 2014 | Dell Inspiron Computers & Internet
What do you do when the screen says replace the fisk and ptess any key when you font have a disk and never have
That means it cannot find a valid windows manager file. Probably corrupt due to errors on hard drive or the laptop was not switched off properly. Press F8 just before it attempts to oot and choose repair or start using last known good configuration.
Dec 16, 2013 | Dell Inspiron Computers & Internet
How to run safe mode
When you start the Computer
Press "F8" key repeatedly after the IBM logo appears, but before the operating system logo appears.
then when menu appears press Down key and Select Safe Mode & Press Enter
If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
Aug 23, 2012 | IBM Computers & Internet
I have a dell inspirion 531 and cannot get it to start...tried f8 & f11 ad nothing works...what r my options to set back to factory
if you've tried f8 and f11 (although i think you should be pressing f12) then there is only one logical step and that is to reinstall. you can download a version of whatever windows OS it came with and use the sticker on the machine for the serial key. you can then go to support.dell.com to download the correct drivers for your hardware.
May 08, 2012 | Dell Inspiron 531s Desktop Computer
What is the function key to boot to restore hd partition?
It depends on the computer. Most modern PCs have it under F8/Repair Your Computer. Some older Compaqs use F10, Older HPs use F11, and older Dells use CTRL+F11. The make of PC and OS would be helpful in giving you better details. I hope this helps!
Sep 23, 2011 | Computers & Internet
How do i restore my Dell XPS M1330 back to factory settings?
Try either F8 or F11 keys
or CTRL and F11 together at start up
May 24, 2010 | Dell XPS M1330 Notebook
How to put my laptop back to factory setting
Try to press F10 or F11 on boot up for most of the manufactures then go for recovery options their are two destructive or nondestructive. for dell in windows xp press ctrl key + F11 in vista press F8 on start up and then select restore my computer.
Mar 14, 2010 | Computers & Internet
Dell Dimension 9100 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
