Question about HP SimpleSave 1 TB USB 20 Hard Drive
My Hp simple save 1 tb external harddrive has been working great. Suddenly today when i plug it in, the blue light flashes once and nothing else happens after that. I can unplug then plug it back in and the same problem happens. It does not read onto the computer and does not function. Ive had it since December and im starting to panic cuz I have everything saved here as a backup, main and I need it.
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Have a 1 tb buffalo external hd. worked great had it for back up. I unplugged it to move my computer. when I plugged it back in, there was no green light no power to the drive. check voltage and the power...
try to test it on other computer or laptop... if the unit are still exist maybe your problem would be the external drive..there are no switch button on it, because most of the switches are located on the adapter, the only testing you could do is to test it to other unit..If the external drive are ok once after you test from other PC's, then might as well check your USB port by plugging-in to other port...or try to use other power supply on your computer, co'z sometimes the supply can no longer supplied any voltage coming from your external drive once it plug-in..
Aug 20, 2011 | Buffalo Technology DriveStation Axis 1 TB...
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
I plugged in simple save external USB drive
ask how to use simple save at HP
read the manual.
http://www.hp.com/ctg/Manual/c01824301.pdf
its just a hdd/sdd external drive.
one can drag files to it any time. using windows explorer.
or run backup programs. of any kind.
Apr 27, 2017 | HP SimpleSave 1 TB USB 20 Hard Drive
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
SimpleDrive 1TB Hard drive not connecting
Windows XP and vista can both automatically detect harddrives, especially with USB connections. The only problem I can see is with the connecting cable. Maybe it is not connected properly. Try another set of cables to see if it solves the problem. Also, try plugging it into another usb port. Also, trying rebooting windows with the harddrive plugged in. Another possibility could be that the device drivers for the drive is corrupted on widows. Go to control panel on windows and look at the device manager and try to manually reinstall the drivers using the disk that came with the harddrive.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
HP SimpleSave 1 TB USB 20 Hard Drive Logo
1,188 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
