Question about HP LaserJet 3015 All-In-One Printer
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when printing a document, only when copying one.
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Posted on Aug 24, 2010
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Wide black line on copy. replaced toner cartridge twice. Can it be the Drum cartridge? 15,500 copies made to date.
If the line is vertical it will either be your drum or fuser are the most likely causes. Visually check each component for the corresponding line on both the photoreceptor drum and the fuser heat roller.
Sep 19, 2015 | Xerox WorkCentre XL2120 Laser Printer
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
HP LaserJet 3015 All-In-One Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
