Question about Sony DAV-S500 System
I want to connect my ps3 in the optical digital audio in, but It dosen't work.... How can i do that?
  • melinatt Aug 24, 2010
    Thanks!!!!! That works perfectly!
  • 4,472 Answers
First off have you made sure that your ps3 is outputting out of the optical audio? Secondly have you made sure your sony is set up on the input you have to accept the optical audio? This link is how to set it up on your sony ps3:
http://manuals.playstation.net/document/en/ps3/3_15/settings/audiooutput.html
As far as the surround sound system i believe the dav-s500 should be set to video 2 to use the optical audio input.
If you need further assistance please let me know.
Thank you,
Lee
Posted on Aug 24, 2010
4 Suggested Answers
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Posted on Mar 18, 2008
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
PS3 Digital Audio (optical) out no longer working
Check you audio settings are correct on the ps3 dashboard. Failing this try swapping the optical cable or connecting to another devise to see if it working.
Post more info if you need further help
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
Audio problems connecting ps3 to bose lifestyle 48 system
Jun 14, 2009 | Bose Lifestyle 48 Series III System
No audio
I beleive that you have connected the HDMI cable to the TV and that you have connected audio out from the TV to the bose system.(I'm assuming that the Bose does not have HDMI connections) it won't work you will have to connect the Digital Fiber Optic out of the TV to the Bose or Direcly from the PS3 to the Bose. Now if you connect it direclly from the PS3 to the Bose you will have to change the audio settings on the PS3 in Audio out from HDMI to Digital Fiber Optic.
Jun 09, 2009 | Bose 3·2·1 II System
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Oct 27, 2007 | Sony DAV-HDX500 System
Sony DAV-S500 System Logo
214 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
