Question about Ovens
I have a lincoln oven it is a 1132-2012778 and I have a code that wont go away....it is a LL code. Can you tell me what to do to make this go away?
Click on the link below and then choose your oven in the drop down list to view the instruction/owners manual. In this manual, you will find what the LL error code means and how to clear it.
http://lincolnfp.com/?xhtml=xhtml/lin/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
Posted on Aug 24, 2010
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
Will not heat after clean cycle, got code but it did not return after being cleared by wife who does not remember code except for the letter F. Element or thermostat how do you tell which is the problem.No...
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, that is the component that typically trips/activates during a self clean on many wall ovens & ranges.
Unfortunately you'll need to pull the oven from the cabinet to gain access to it.
If you pull/slide the unit away from the wall and unplug it you can replace the hi-limit...you will likely require two people or if you have a couple of "saw horses" or the like to slide it onto.
It will be a non-reset type hi-limit (based on the model number you posted) so needs to be replaced as I mentioned, doing so will get you back up and cooking in no time.
**Unplug or turn off the breaker of the wall oven first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like this...
Replacement part number is typically $30-$40US. # 3879224 and available on-line at vendors such as "appliancepartspros.com" "repairclinic.com" or "searspartsdirect,com" to name a few.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Sep 09, 2011 | KitchenAid KEBC147 Electric Oven
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
May 07, 2010 | Lincoln Conveyor Oven - 1132-000-A
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at maugoro@yahoo.com
Feb 05, 2010 | Lincoln Ovens
Whirlpool Acu Bake oven, burners light, broiler lights up, but oven wont light up. Oven ignitor lights up (glows) but it appears gas is not coming on, thru oven burner. Could the ignitor be bad even if its...
You just need a new gas valve. This is a simple repair for you and you can save a lot of money by repairing it yourself.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number and we will get the correct part out to you right away.
We look forward to getting you cooking again soon.
Nov 06, 2009 | Ovens
I turned on the main switch,but nothing works
main fuse is on the front panel with the blower fuse
Feb 07, 2009 | Lincoln Conveyor Oven - 1133-000-A
Lincoln Impinger Pizza oven 1301 model number
this could possibly be caused by the brushes in the conveyor motor. they might be worn out or sicking.
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
I have a lincoln impeger pizza oven and it wont come on
The oven temp high limit is on the back. Depending on model there is a control box high limit that you need to open the control box and locate. If this is the case, make sure the cooling fans are running.
Dec 13, 2008 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
