Question about HP Office Equipment & Supplies
The cartridges are always jamming up. The printer is 4 years old -- time to buy a new one???
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
I have a Konica Minolta Magicolor 1600w which has not been very reliable. After a year I had to replace the fuzer. When the toner ran out, I decided to buy another one since it's cheaper than buying...
the second printer who made that? you bought a new 1600w?? and no you can not use the new cartridge in the old. go out buy new OEM cartridges for the printer the first one. on the new printer. did you clean the rollers did you ensure the printer setting for the media (paper) was the same as on the computer. was paper properly installed landscape versa porait.
Mar 24, 2017 | Konica Minolta Magicolor 1600W Printer
Printhead cartridge jam code 3527
Contated Kodak about the error code 3527 and was advised I needed to purchase another printer and they would give me a 30% discount. Why would I do that when my Kodak printer is only 14 months old! My Dell is 9 years old and works fine! Dell ink cartrides are expensive and can only be ordered online. That is why I switched to Kodak. Do not buy Kodak!
May 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges...
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges for the printer which is over a year old. How can I fix this problem?
Jul 11, 2009 | HP Office Equipment & Supplies
Just opened box today 12/14/08 error msg: cannot recognize ink cartridges. I just completed step 4-9, checked cartridges 4 times pressed OK BUTTON 4 TIMES, same msg. note: all cartridges are new! checked  ...
Same problem with the one I have. Have always had that problem. Seems like cartridges from Mexico work better. If at first it dont work, JAM IT IN. What the hell, if the printer breaks, you aint lost nothing but a printer that wouldn print anyway.
Dec 15, 2008 | Epson RX595 Photo All-In-One Printer
Error e 3 with mp150 but no papper jam
this is a paper jam,
As the machine is a old model you might as well strip the machine down and inspect it for any lose paper, it could be the reg sensor has bent causing it to always say the same error.
by the time you have tried all this i would maybe look to buy a new machine with a years warrenty from Canon
Hope this helps
Oct 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
May 28, 2008 | Minolta magicolor 2300W Laser Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
13 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
