Question about Maytag Neptune MDE5500AY Electric Dryer
Squeaks for a few min then goes away. maybe a roller?
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.(Some dryer lids will tilt back)
Also remove the screws holding the lint filter in place and remove the lint filter also.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Aug 24, 2010
Squeaks for few minutes then is find ,concern about balance or belts ,
It maybe rollers what is the model number from the model tag.
Jan 30, 2014 | Kenmore Elite HE4 Electric Dryer
SQUEAKY!
Petroleum will rot bushings, you may consider a car wash with and undercarriage sprayer and see if noise goes away. This may indicate a bushing problem if noise goes away. If not, ball joint probably.
Jun 28, 2013 | 1999 Ford Expedition
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
It was squeaking for a few days, and now it keeps on stopping by itself every few minutes.
Sorry to read about your problem, I hope this helps you out.
Their can be many places, where squeaks can come from.
80% of the time, it comes from the belt tension roller, as the unit heats up, the sound may get worse, or go away.
Your unit may have drum rollers, they can go bad.
Your unit may have a defective drum bearing and last but not least, you may have a defective motor bearing.
In all cases, the parts will need to be replaced.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Dryers
My Gestetner dsc530 is squeaking when it prints.
A lot of the smaller copiers get random squeaks and squeals from time to time. Eventually some of them will go away, but if you want to try to get rid of it yourself, a can of compressed air is a good place to start.
Try to isolate the area where the squeaking is coming from, and blow some air into that part. Many times the squeak is from dirty bushings or rollers.
If that doesn't help and you can isolate the noise to a specific set of rollers, clean the rollers with either alcohol or D-ink and see if that makes a difference.
Jun 30, 2010 | Gestetner DSC530 All-In-One Laser Printer
I have an Amana (M# ALE643RBW), when started the dryer squeaks for the first 10 minutes of the cycle, then slows to a squeak every 7 minutes... why? Maybe a bit of lube?
I have the same problem. While I have not fixed it yet, I assume it is a drum roller. Most dryers have two 4 to 5 inch diameter drum rollers which hold up the dryer barrel in the back. These drum rollers are wheels which have rubber on the outside where they touch the drum and a metal hole in their middle. They turn on a metal rod which goes through their middle. As the inside of the wheel turns on the rod, the metal gets eaten away and they squeak. Replacing one or both drum rollers should fix the problem.
Nov 25, 2009 | Amana Dryers
IBM Wheelwriter 3 squeaks.
The squeaking is caused by lack of lubrication on the Platen (roller) bearings..the feed rolls that grip the platen or the linespace mechanism. Have to be careful on too much oil..I just put a drop on a corner of a piece of paper and touch what you want to oil..it will **** the oil right off the paper. a light oil like gun or sewing machine oil.
Hope this helps
Squipps
Oct 06, 2009 | Lexmark Wheelwriter 3 Typewriter
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
227 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
