IM TRYING TO BURN A MOVIE AND THE BURNER KEEPS SAYING TARGET OVERFLOW. HOW DO I FIX THIS PROBLEM
  • 666 Answers
U need to use a larger recorder dvd the file is to large to fit onto whatever format your using
Posted on Aug 24, 2010
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Keeps asking for blank dvd
check roxio configuration the check if it is using the right drive.
sometimes the burner programs try to burn discs in virtual drives.
Jun 02, 2010 | Roxio Easy Media Creator 7
When i push copy on my DVD burner it says,Target Overflow,what do that means becouse it wont let me burn nothing its a[ TEAC 1 1 DVD/CD duplicator]
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank disc..it's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
Recommended:
Verbatim
SONY
Ritek
Ridata
May 08, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Trying to burn dvd. It keeps saying Target drive not ready
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Jul 17, 2009 | Telex SpinWise 7-824D (301689000)...
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Can't connect to computer
Hi, You need to first capture the video using Windows Movie Maker.
Then the movie maker will let you burn it to a DVD/ CD
Nov 16, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Sense error
Every time i try to burn my home from windows to a Philips DVD-RW a message keeps popping up from my laptop saying that i need to place a DVD-RW cd in which i have done . The funny thing is that i edit my movie from my Pinnacle Studio 12 which i got last week, this was my 1st movie i burned well Pinnacle Studio did it for me really, it was so easy when i took the cd out of my hp pavilion laptop it played on my LITEON DVD Recorder & watched my movie clip on my tv, it worked fine but do you think i do this again NO SUCH LUCK i am really new to all this its so frustrating windows wont burn my move pinnacles not burning, what am i doing wrong, i ve got all new dvd-rw cds is there any one out there who can help me please :-(
Oct 05, 2008 | Computers & Internet
TARGET OVERFLOW ? / ARS-2030 LD COPY SMART PLUS
Your source dvd is most probably a 8.5Gb disc. You will need a blank 8.5Gb disc to copy to.Check out the size of the file on the source disc or the capacity of the source disc. If it is greater than 4.7 Gb.If you are using a 4.7gb to copy to,it will bring up an Overflow message.
Dec 23, 2007 | Acard Technology (ARS-2030LD) DVD±RW...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
