I am trying to connect a Dell Laptop (Windows XP) to a Brother MFC 640 CW printer that is wirelessly connected to a Linksys router. The printer is authenticated to the router (or at least is says that it is). However, I cannot connect to the printer through the router. Any advice?
  • ccody156 Aug 24, 2010
    Specifically, an unwritten step 16.
    It should probably start something like:
    In Microsoft Windows XP, Open Control Panel.
    Open Printers. Select "Printers and Faxes"
    Select Add Printer:
    It is the rest that is not working. I have the IP address (192.168.1.101) of the printer and the default node name (BRW_757210).
    But none of the available options can connect me to the printer.
    the router.
    I have tried the following solution: http://welcome.solutions.brother.com/BSC...
    However, it says nothing about getting the laptop to find the printer that is now configured to the router.
    I have installed the factory drivers and been through all thinkable installation routes through the install wizard.
    Except for those requiring a direct cable connection (the instructions there are vague as to whether the laptop and/or printer need to be hard cable connected to each other).
  • 4,924 Answers
Http://www.ehow.com/how_2091717_access-printer-through-wireless-router.html
The idea it should have been much easier if the printer was connected to one of the computers connected to the router ..and from faxes and printers you should choose the printer amd right click on it ..give it a name and select the properties to be shared..
after that all you had to do is to search for a printer from the faxes and printers..and when it find it ..send the print job to it ..
but here is about the same ...if all is installed..(try to install the driver in the laptop to ..just in case) ..than go to faxes and printers..choose network printer ..and if it finds it ..just select it and print ..
Posted on Aug 24, 2010
  • Catalin Turcu
    Catalin Turcu Aug 24, 2010
    if all is connected well all you have to do ..is go to Start ...click on printer and faxes from the start menu ..than click add printer ...A wizard will get on ..and you have to select a network printer ..and after that let it scan for printers...select the printer you want to use from the list ..and next ..
    after you added the printer with success..all you have to do is to open what you want to print and click print ...from the file tools..it will send the job to the printer selected auto...
  • 4,472 Answers
Here are all the steps to get your printer set up wirelessly. If you run into an issue please let me know exactly at what step and I will try and assist you further.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000069/faq000469_000.html?reg=us&c=us&lang=en&prod=mfc640cw_all
Thank you,
Lee
  • Lee A.
    Lee A. Aug 24, 2010
    Our message system may not be working properly did you get my message or give me any feedback?
  • Lee A.
    Lee A. Aug 24, 2010
    Refer to page 72 of 164 of the owners manual pdf for the exact steps on how to get the wireless printer setup on your computer here is a link to the manual:
    Follow those steps and there should be no problem setting it up, make sure a firewall on your computer isn't stopping it from connecting.
    Thank you,
    Lee
Laptop does not find Brother MFC-J435W Printer via Linksys E1000 router
Usually you need the printer driver to be installed on each device( PC- yes, but not sure how you would do the Iphone). Also verify that you have done the IP settings within your printer and that your computer can seethe printer
Dec 08, 2012 | Brother Network-Ready Wireless Color...
Hello, I have a Brother MFC-5890CN Printer/Fax/Copier which has a wired connection to my PC (Windows 7) & works very well. However I would also like to be able to access the MFC-5890CN from my Laptop...
download the brother network deployment wizard. Run it and
make and executable. run that exe on your laptop. It should do all
the necessary config for you
May 01, 2011 | Brother MFC-5890cn Color Flatbed...
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
How to use brother mfc 495 cw wireless to my computer do not have manual
i am trying to install the printer software and it is saying it needs to be configured to the wireless router, HOW DO I CONFIGURE IT TO THE ROUTER? I HAVE A BROTHERS MFC495-CW WIRELESS PRINTER.
Apr 23, 2010 | Brother MFC 420CN All-In-One InkJet...
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
I cannont connect my Brother MFC-9840W wireless printer to my Linksys WRT160N router. It says "Connection NG" every time I run the setup in the printer menu. I have verified the correct key is being used.
i think this can be fixed . first reset the router settings and reset the printer also. and now try to setup the connection with advance settings as manual says . for more help contact brother
Printer Tech Support . i hope this will help thanks
Sep 30, 2009 | Linksys WRT160N Wireless Router
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
24 people viewed this question
jasbo
jasbo
