Question about RCA HD52W56 52" Rear Projection HDTV
Rca projection tv model # p52753at
I bought this tv from a friends parenta its old but works great for our lake cabin. it worked fine and then the next time i was there when you turn it on it will turn its self off and on and then off for good.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
It has circuit broken .short call tech.
Posted on Aug 03, 2008
How can i clean the lens and mirror on my RCA projection TV modol P46725SKLG1
i have an rca home theater model p52753at and the lenses and mirror was dirty and i tore it apart and cleaned everything and put it all back togeather and had a beautiful picture no problems and if you use the svidio prot and cable you get a better picture too does any one know where i can get the convergence repair kit for this tv/ thank you tom putnam 989-205-6464
Mar 06, 2011 | RCA Televison & Video
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
DO YOU WANT THIS INFORMATION?
A VERY HELPFUL RATING IN RESPONSE TO THIS SOLUTION WILL TELL YOU HOW TO GET INTO THE OPTION MENU.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
RCA Projection tv has great picture but no sound. Model #P60812BL
normaly the audio ics go bad cap or 2 make sure audio sing is present on input of aud ic if so chk opt if opt bad replace ic and capacitors around ic good luck this should fix ur prob parts nte semiconductor.com 25.00$
May 18, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" Projection TV P52753AT
On my 52 projection TV P52753AT I found that one of the Kine Sockets burned so it is just a matter of replacing it if I can find one or rebuilding it. And yes that will give it the clicking sound when you turn the TV on. I'm just glad I am a computer tech and I enjoy doing this kind of thing for a living.
Thanks
Wesley B Wilhite
Jan 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D61W130YX1 chasis AYCZZ1 Serial# C425C101C
hi there do you have sound ?? if so open the back and check for a bulb youself as i dont trust shops much anymore becaues they always want you to replace old models.
richard
Oct 15, 2008 | RCA D61W20 61" Rear Projection Television
Tv stop working
That model is famous for bad flyback which is what I believe is your problem as well. The flyback is the HV transformer.
Apr 11, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
