Question about Kitchen Ranges
I have a Kenmore Elite dual-fuel oven/range. It was working fine until we did a self-cleaning on the oven. Now the bottom burner/element no longer works.
  • sledger666 Aug 24, 2010
    Since I cant find the model number on the doors or in the oven itself, I can only assume it is on the back of the unit (which is very hard to get to due to the cabinet configuration - aka tight/no wiggle room). As it is difficult, if I am to pull it out , I would like to take the opportunity to do some troubleshooting. Any thoughts on how to best proceed?
  • Kitchen Ranges Master
  • 8,220 Answers
Maybe a bad element or limit has popped. I am assuming you have an electric oven for even heat and gas burners on top for controlled cooking. Pretty cool. No pun intended. LOL It might be the element but I suspect a limit has opened or failed. No way to know without doing a looksee. AND no way really to give a good answer because a Kenmore might be any brand from LG to Electrolux.
Post the model number of this beast for a better answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 24, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Aug 24, 2010
    pull out the bottom drawer and look on the frame
  • Dan Webster
    This video shows how to check the high voltage stuff
  • sledger666 Aug 26, 2010
    found the model number (thanks - never would have looked there)
    790.75503200
Does it have 2 plugs 110 and a 220
This is the oven spec, so it has to be 220 volts to support that wattage. The oven and broiler are electric and the hob is gas. Best of both worlds. (I am a chef)
Oven-Bake Element 2500 Watts
  • Oven-Broil Element 6 Pass 3400 Watts
    and then I found this :>)
    Power Power Supply Connection Location: Left Bottom Rear Gas Supply Connection Location: Right Bottom Rear LP Gas Conversion Kit: Included Voltage Rating: 240V / 208V / 60 Hz Connected Load kW Rating at 240/208 Volts: 3.7 / 2.8 Amps at 240 / 208 Volts: 15.4 /13.5 Minimum Circuit Required: 30 Amps
  • Frigidaire FGDS3065PF 30 Slide In Dual Fuel Range with 4 Gas Burners...
    Jan 31, 2016 | Frigidaire Gallery 30" Self-cleaning...
    I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
    Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
    With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
    http://www.searspartsdirect.com/
    This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
    How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
    Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
    Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
    It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
    Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
    Frigidaire Range Control Board Repair Service 318010102
    Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
    Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
    Pressed the Clean Button
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    Jul 16, 2010 | Kenmore Kitchen Ranges
    Kenmore Range/oven Burners won't lite
    Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
    May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
    Diplomat elite (MFI)
    it is dangerous there is a short do not use until its been electrically checked out. eg resistance to earth.
    Mar 25, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
    Oven will not work
    It sounds like the Thermostat is defective.
    Element can be removed from the front of the unit, it does not need to be pulled
    Oct 27, 2008 | Viking 48" 6 Burner, Grill Professional...
    Kitchen Ranges Logo
    50 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
