Question about Zenith Z25X22S 25" TV
Where is the vertical adjustment knob on the Zenith Z25X22S and how do I get to it?
  • 70 Answers
Many new TV's having vertical hold most of the case you need service mode to change the setting
Posted on Aug 27, 2010
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Zenith 25" model z25x22s has hardly any green
Check the green output section circuit at the video output card for any loose soldering. This card can be located at the neck of the picture tube itself, will directly plugged to it. You can pull it out of it for repair. Re-solder all the suspected solder terminals there.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 16, 2013 | Televison & Video
The picture on My Zenith TV is not centered. How can I fix it?
there are adjustment knobs located on the pcb for the horizonal and vertical holds. try adjusting these to fix your problem.
Aug 08, 2010 | Zenith C36V23 36" TV
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
Image on screen cropped. can't find menu items to adjust screen size.
on the back side of set should have a control that says vertical size/ sweep. it is recessed into a small hole or has protruded knob, if so used a small flat tip common screwdriver for the adjustment. make sure you can see the control knob or slot clearly otherwise you could short out something!!!!!
Sep 21, 2009 | Zenith A27B33W 27" TV
Need manual for zenith z25x22s
need code for a 1997 Z 25 X 22S Zenith TV .
Have the remote , bought used tv , but remote is not working . It has a prgram buttom on top left of remote
Jul 03, 2009 | Zenith Z25X22S 25" TV
Programming stock remote
Most original remotes are non-programmable. I would get universal for $5-10
Jun 11, 2009 | Zenith Z25X22S 25" TV
No Picture
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Sep 16, 2008 | Zenith Z25X22S 25" TV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Televison & Video Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
