Blue line through screen om mintek mdp-1050 - Televison & Video
  • 3 more comments
  • bukination29 May 05, 2008
    it is a portable dvd player that will display via dvd usb or memory card has acoaxial input , av in and av out on the side
    yes all dvds and even during no disc menu displays and screensaver
    mintek mdp-1050 portable dvd player Screen has a blue line through the screen
    Comment by bukination29, posted on May 05, 2008
    President:
  • 2,712 Answers
Hello bukination29,
It looks like there is an issue with the LCD display due to a defective resistor or the vertical blanking or a faulty soldering in the PCB. This, unfortunately, is not something that you can repair yourself. Try hitting it gently on your palm and see if it makes a difference. If you see anything different, it could indicate faulty soldering.
If your device is under warranty, I suggest you get it replaced. If not, then I'm afraid there is no other option but to take it to a repair shop to get it fixed.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
    Brigadier General:
  • 6,966 Answers
Hi bukination29,
with the indulgence of IB4G2008...
You have to treat it like the LCD display of a laptop. The display panel has to be opened and the connectors inside the video interface/buffer has to be checked, it may just be loose connection. In certain instances it may be the flexible flat cable leading from the display panel down to the DVD deck area. Often problems with the flexible flat cable is an open wire or trace/strip.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 3,587 Answers
Hmmm...is this not the case when viewing anything else? Let's eliminate the video portion, first..can you use that for anything else, like a VHS or VCR input?
  • Patrick Michaels
    Patrick Michaels May 05, 2008
    nope..nothing else..pure portable..does this happen with all DVD's you play?
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
MIntek MDP-1815
Either the glass laser eye lens is dirty, or faulty. You can first try to clean with rubbing alcohol and cotton swab. If cleaning doesn't help, re-download drivers and cd-rom software. If problem still persists, get new laser eye unit or rom drive
Sep 15, 2009 | Mintek MDP-1815 Portable DVD Player
I use my dvd player everyday. the model is a mdp
Sounds like the power pack/charger is at fault.
Test with a tester or bulb(correct voltage, will be written on power pack/charger) and a piece of wire.
Check for a blown fuse in the mains plug.
Aug 26, 2009 | Televison & Video
Mintek MDP-1760
My Mintek MDP-1760 try to loading the dik and later show a mesage NO DISC... what is the proble?
Jan 30, 2008 | Mintek MDP-1760 Portable DVD Player
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
