Hello , I have a 1971 seeburg jukebox that has several problems. Any info. or tips would be great. 1.It has been set to free play, so no money is required. When you select a song number you can hear it click and the song's number is illuminated on the number strip. But then it will not do anything after that , like it is not sending a signal to the turn table to begin playing the record. It will play records if you open the top and manually start it with the switches down by the turntable. Which brings us to problem #2. 2. When you start it manually you can faintly hear the music from one of the top horn speakers. The volume knob on the back is turned to high. Could this be the power amplifier or something else. I don't know . P.S. Thanks, Jimmy
  • 3 Answers
You could have blown main lower speakers, loose connection or bad caps or transistors on the power amp. it's hard to say without looking at it. Sme with the selecting problem, sounds like a problem with the tormat.
Posted on Nov 14, 2011
  • John_Kay Nov 14, 2011
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
I just picked up a seeburg jukebox model sps2 serial number 1 (not sure what that means) but it's my first one and it looks clean inside other than clean up, powers on and hasa hum sound, up on the...
I'm not sure if the other answers even come close to answering you questions.
Since you know nothing about it you might want to get a manual first off.
More info on your model here - http://www.jukebox-world.de/Forum/Archiv/Seeburg/SeeburgMatador.htm
There are selection trouble shooting & help are located here - http://www.ebay.com/itm/231698068028?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Additional tips
All light bulbs
that are located in the key pad "light box" "First digit", "Second digit", Reset / Re-select etc.. are controlled and LIT BY THE SELECTION COMPUTER. They must have the correct bulbs installed! These are special 28V bulbs. Depending on your particular jukebox model, you NEED to use one of the two types listed below.
GE 656 - 28V .06A 2500HR LIFE T3 1/4IN WEDGE BASE MAN19600 EIKO BRAND or
GE 1819 - 1.12 WATTS 28 VOLT BA9S SINGLE CONTACT BAYONET, 9MM DIAMETER.
Installing a 6 or 12 Volt bulb here will cause damage to either your replacement box, and / or the resistors that are located on the small circuit board on the back of the light box. (These resistors are inline on models using 1819 bulbs)
CAUTION
BOTH lamp types look exactly like 12v bulbs, BUT THEY ARE NOT, and are often mistaken for 12v bulbs. This is a very common mistake made by many Seeburg owners, so be careful with this.
Mar 01, 2015 | Audio Players & Recorders
Seeburg jukebox ay160 won't select record
(1) Make sure that the credit unit is not stuck and that all of the contacts open and close correctly while manually operating the solenoids. Lubricate it if the wheel does not turn freely. (2) Make sure that there are credits on the machine. (3) If it still wont select check fuses or (4) try pressing the letter and the number simultaneously, some "free play" set ups will work this way.
Jun 09, 2012 | Audio Players & Recorders
I have a 1971 SEEBURG MODEL USC2 "Bandshell"
Tormat has been energized by movement over the carpet, someone touching it with a high charge or natural static in the air of a dry house. There is a procedure to deenergize the tormat with a battery. I am searching for the battery size and procedure myself. I will come back if I find out
Jan 11, 2011 | Audio Players & Recorders
How do you set the Rockola 480 to free play?
For free play on Rock-Ola 480. Open your jukebox, on the right,you will see a large metal box marked Profit Setter. In this box are Sections A, B and D. In section D, you will see very small white buttons on a pink background. Push ALL of the buttons in section D to the left with a pen.It will play for free until changed. For money, put it back like it was. It will also play all songs automatically. If you wanna know that, e-mail to varnett1@woh.rr.com
Dec 16, 2009 | Vintage Jukebox External Speakers Shelf...
Seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
I have a 1971 seeburg firestar jukebox - the zero (0) does not seem to work when you punch in the 3 numbers for the selection - so none of my selections that have zero in it do not play - also I do not...
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Mar 07, 2009 | Audio Players & Recorders
143 people viewed this question
 Grubhead
Grubhead
